95.5 actual model year? - JeepForum.com
post #1 of 9 Old 04-21-2001, 02:48 PM Thread Starter
Tonka
2015 JK Wrangler
Just wondering if 95.5 was an official model year. My 95 was built in June of 95
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #2 of 9 Old 04-21-2001, 04:25 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
The way the auto companies look at the calendar it would probably be a '96.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 9 Old 04-22-2001, 04:03 AM
jeffy
jeffy's Avatar
You know one way to see when you're Jeep was made is to look at the engine block. There is a date stamped onto it. Then add 2 months or so for the completion of the Jeep.
I was lucky enough to get the paper they use to sign off a Jeep as it comes off the line. Depending on the year it could of been made as early as mid 95 or as late and early 96.
*** www.4BangerJP.com ***
jeffy is offline
post #4 of 9 Old 04-23-2001, 01:40 PM
rayray
rayray's Avatar
Tonka,
The most obvious way to tell is by some small little bolt on's. For instance, the 95.5 uses the same windshield bumpers as the TJ. Also, the 95.5 has TJ hinges on the rear door. Other little odds and ends are differant as well.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #5 of 9 Old 04-24-2001, 12:38 PM Thread Starter
Tonka
2015 JK Wrangler
Thanks, then mine is a plain 95, would 97 and up rear door hinges work for it, or is the bolt pattern different. I like the lower profile hinge
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #6 of 9 Old 04-24-2001, 05:56 PM
rayray
rayray's Avatar
It's a little differant, but the hinge should cover the old holes. I'll look when I get home.
rayray
rayray is offline
post #7 of 9 Old 04-26-2001, 12:11 PM
JPFREEK
JPFREEK's Avatar
Because JEEP had no '96 Wranglers produced (officially), a '95.5 is still considered a '95. Another difference is the D-35c housing, many '95's have the ABS housing even though they may not actually have ABS.
-Pete
'91 YJ
JPFREEK is offline
post #8 of 9 Old 04-26-2001, 12:54 PM Thread Starter
Tonka
2015 JK Wrangler
I'm one of the lucky ones with the abs carrier. Found that out when I ordered my lockright. I hate paying for shipping twice
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #9 of 9 Old 04-26-2001, 07:52 PM
jeffy
jeffy's Avatar
The ABS carrier in non-ABS Jeeps started back in 91. Everyone kept insisting I had a ABS carrier when I didn't. It was done to standardize some parts between the options. 1993 was the first year that ABS became a option. I think.
As for the hindges. From the 95.5' I saw, the hinges are kind of like the TJ's but not exactly. They were probably trying out designs to see if they worked. Should be interchangable with pre-95's since they use the same bolt holes.
jeffy is offline
What year model is the most reliable? sopwith Wrangler General Discussion 25 10-12-2012 10:40 AM
?'s with model year of my 44. yjjustforme YJ Wrangler Technical Forum 7 04-28-2009 08:53 PM
What model/year is my hard top from? Mark05059 YJ Wrangler Technical Forum 14 03-13-2009 05:37 AM
Actual price vs. MSRP? Two door model mgaspard JK Wrangler Technical Forum 24 06-12-2007 11:57 PM
Hard Top vs. year model jeepsgotnutz TJ Wrangler Technical Forum 2 06-28-2006 04:31 PM
