For a stock 1995 wrangler, What the hell is the shift pattern? I can't seem to get it any lower then the 2nd one down (pulling towards me). If i can put it in 2H so i can not mess up my transfer case too bad that would be ideal. Thanks.
the NP-231 T-case works like this.. All the way up and to the left= 2wd One back = 4HIGH. from 4 high move the stick to the right and down one position and you should have Neutral, then one back from neutral you should have 4 low
Are you asking about the 4W transfer case.
all the way forward is 2H
Pull back to 4H
Then push toward passenger side and pull back again for N
then pull back again for 4LOW
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
