95 4cyl 5spd MPG? - JeepForum.com
post #1 of 5 Old 05-21-2001, 04:26 AM Thread Starter
Naum42
95 4cyl 5spd MPG?
I just got myself a 95 Wrangler with 53,300 miles on it, and 31x10.5 tires without any lift. (Yes, they do rub on things sometimes, that will hopefully be taken care of soon). Reading the specs I should be getting about 19MPG, however I seem to be getting about 15MPG. Are the bigger tires enough to make that big of a difference? If not, what else should I be looking at? BTW I run super in it.
Naum42 is offline
post #2 of 5 Old 05-22-2001, 05:50 AM
smithbuiltYJ
I have a '95 4 banger, with 31x10.5 Goodyear AT/S tires. I went from 20 mpg to 18 mpg (city) when I went with the larger tires. What kind of tread, and how much pressure are you running? MT/r's would probably be a little less on mileage than all terrains, and lower pressure would also be less mpg.
HTH
Marshall
'95 YJ, "Toy Story", some mods done, some mods on the way.
smithbuiltYJ is offline
post #3 of 5 Old 05-22-2001, 10:02 AM
Tonka
2015 JK Wrangler
95 4cyl 2.5L 5 speed 31x10.50R15 bfg muds.
I get about 10 mpg due to stock gears and a bad catalytic converter(hard top & doors)
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 5 Old 05-23-2001, 06:26 AM Thread Starter
Naum42
Thanks for the replies...they are Wild Country Radial TXRs running at 32PSI right now. They were actually studs, and the guy I bought it from took the time to pull all of the studs out because he didn't have the $$ to buy new tires :-)
Naum42 is offline
post #5 of 5 Old 05-27-2001, 11:11 AM
scooper
probably has alot to due with your tires and how you drive,do you often find your foot to the floor due to the 4 bangers power output.
scooper is offline
Pitman arm on 1997 4cyl 5spd Swift_JK TJ Wrangler Technical Forum 3 08-06-2009 08:48 PM
Simple RPM question for 4cyl 5spd TJ danheit TJ Wrangler Technical Forum 10 01-16-2009 10:02 AM
90 4cyl - 5spd to a 5.0l nickaldrich YJ Wrangler Technical Forum 2 10-19-2006 08:38 AM
Co$t to add A/C to a 1997 SE 4cyl 5spd? 4wdNewbie TJ Wrangler Technical Forum 6 08-20-2006 10:56 AM
New '02 2.4L 4Cyl 5Spd Rattle!!! kgoode80 TJ Wrangler Technical Forum 1 05-24-2002 06:17 PM
