95 4.0 YJ failed Emissions. - Page 2 - JeepForum.com
post #16 of 27 Old 04-11-2013, 05:33 PM
Que89YJ
that is high. since it isn't changing when you disconnect the vacuum check to make sure there is vacuum on the line going to the regulator. If there it's then you have a suspect regulator. I am surprised out it's high. That is counter intuitive to your issue but it is wrong.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 27 Old 04-11-2013, 05:45 PM Thread Starter
Robob69
There is plenty of vacuum for sure. I ordered a new regulator. Will be in tomorrow. Can we eliminate ecu and injectors? Or are they still suspect?
Robob69 is offline
post #18 of 27 Old 04-11-2013, 05:48 PM
Siva283
What's the current condition of the plugs wires cap and rotor? Also did you reset the ecu after each change. Especially the o2 sensor.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #19 of 27 Old 04-11-2013, 06:11 PM Thread Starter
Robob69
That's one thing they did not do was reset the ECU .. plugs rotor and cap were changed last year when it failed when I bought it.. then it was the cat converter.
Robob69 is offline
post #20 of 27 Old 04-11-2013, 06:41 PM
Siva283
Might be worth checking the plugs anywah. Atleast it doesn't cost anything.
Siva283 is offline
post #21 of 27 Old 04-11-2013, 07:33 PM
Que89YJ
Reset its necessary after any sensor replacements. Good catch.
Fault codes:
No Start:
Que89YJ is offline
post #22 of 27 Old 04-11-2013, 08:23 PM
superj
So are you saying a 95 4.0 yj could possibly be coming up for sale in the near future?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #23 of 27 Old 04-11-2013, 09:14 PM Thread Starter
Robob69
Hahahaha.... I will so register it in another county without emissions. .. Good try..
Robob69 is offline
post #24 of 27 Old 04-15-2013, 06:11 AM
Que89YJ
Did you get it figured out?
Que89YJ is offline
post #25 of 27 Old 04-15-2013, 07:09 AM Thread Starter
Robob69
No... Have not had time. Replaced the fuel regulator yesterday then my freaking ignition lock jacked up and can't start it now until the new lock assy comes it sometime today...
Robob69 is offline
post #26 of 27 Old 05-12-2013, 12:06 PM
bill8bud
Any updates on this I am a similar issue.
bill8bud is offline
post #27 of 27 Old 05-12-2013, 01:02 PM Thread Starter
Robob69
Sorry.... I passed and forgot to update.....
I changed my fuel injectors and cleaned the throttle body and it passed with flying colors.
Runs perfect and has huge amounts of get up and go now,,
Amazing what 4 hole injectors can do...
Robob69 is offline
