94YJ Rear Brake Light Wiring Diagram - JeepForum.com
post #1 of 3 Old 01-13-2009, 09:04 AM Thread Starter
PaulGarch94YJ
I am currently installing a third brake light and it has three lousy wires (one obviously being a ground wire) and I hooked it up to the factory pins that are in the door and it does not work...I then re grounded the light and bypassed the pins (NOTHING) I then proceed to tap the rear brake lines directly however I think that I have the wrong + wire that goes to the brake light... Does anyone know which is the brake light and which is the backup light? My colors on the connector are only Green in the middle and two whites. This is the same on both connectors.... When I tap the brakes I get power on the green wire according to my meter...Oh and by the way I am an a Electrician so I know the Physical connections are right but I do not have a diagram to tell me the wire colors...
Thank you for any input you may have...
PaulGarch94YJ is offline
post #2 of 3 Old 01-13-2009, 09:35 AM
Alfons
Try searching this site for threads on wiring diagrams. There have been a few in the last week or two and several links to wiring diagrams available from Pirate 4x4. The wiring for the lights (front & rear) is also covered in manuals like Haynes (they aren't accurate for all their wiring, but I believe this part is OK).
Alfons is offline
post #3 of 3 Old 01-14-2009, 08:12 AM Thread Starter
PaulGarch94YJ
Thank you very much
Brake Light Wiring Diagram wooterjeep TJ Wrangler Technical Forum 3 04-22-2011 12:56 AM
Fog Light Wiring Diagram rebelkid17 TJ Wrangler Technical Forum 6 12-18-2008 04:06 PM
Wiring LED rear brake light UTWeezul TJ Wrangler Technical Forum 2 03-14-2008 08:17 PM
Parking Light Wiring Diagram nckm126 TJ Wrangler Technical Forum 1 12-25-2006 12:52 AM
Need O2 Sensor Wiring Diagram for 94YJ seanw YJ Wrangler Technical Forum 3 01-06-2003 01:42 PM
