94 YJ vibration - JeepForum.com
post #1 of 6 Old 11-30-2001, 04:21 AM Thread Starter
bonehead99
bonehead99's Avatar
94 YJ vibration
I recently installed a RC 3" lift kit and when I'm going 45-52 mph I get a vibration. It feels like the rear driveshaft, I also have 2" shackles. Could I need another degree of shim?
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 6 Old 11-30-2001, 07:12 AM
gifargis
You either have to place a SYE kit to illiminate the problem and change the drive shaft to accomidate the longer length.. or I just threw a 15 degree shimmy under my leaf spring to get the correct angle...
That could be one problem .
Did you lower the transfer case?
if not, this is problem number two
sargon
See y'll on the trail.
gifargis is offline
post #3 of 6 Old 11-30-2001, 08:51 AM Thread Starter
bonehead99
bonehead99's Avatar
I did lower the t-case. Does it matter that the spring already have a shim, can put another shim on top of it?
post #4 of 6 Old 11-30-2001, 09:21 AM
osburn
osburn's Avatar
I'm assuming the tcase drop and the shims came in a kit. If so, it's probably not angle, it's probably a u-joint failing on you. Get under there and shake the crap out of the driveshaft. There shouldn't be any play other than a slight amount of rotation.
Matt Osburn
Score 1032
osburn is offline
post #5 of 6 Old 12-01-2001, 09:31 AM
Brendan
If you have a 3" suspension and 1" shackle lift, you are asking for vibration. Dropping the T-case decreases your ground cleareance, and can affect your shifting. Just save for the slip yoke eliminator kit. It will solve most of those vibration problems. With shims you are temporarily fixing a problem that will need permanent fixing later.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #6 of 6 Old 12-01-2001, 11:34 AM
osburn
osburn's Avatar
I'm glad you replied to this Brendan, cause it made me read it again. I didn't catch it was a newly installed lift the first time around for some reason.
First, DO NOT stack shims! Bad enough ya gotta slip something between your springs and perches as it is. Expect to install a longer center pin on your springs when you add a thicker shim. The center pin needs to go thru the shim and into the perch.
I'd suggest you get under your Jeep with an angle finder (cheap tool to buy) and measure your driveshaft angle and the angles of your yokes. Figure out how much shim you need and slip them in.
If it were my Jeep, the lift shackles would be outta there! They're probably the worst way to obtain lift.
Matt Osburn
Score 1032
osburn is offline
Bad Vibration. Please Help? metal_kid17 YJ Wrangler Technical Forum 8 10-26-2009 02:52 PM
Bad Vibration. Manard TJ Wrangler Technical Forum 3 02-25-2008 05:26 PM
Odd vibration JeepPirate TJ Wrangler Technical Forum 4 01-14-2008 12:03 PM
vibration igolf JK Wrangler Technical Forum 20 12-17-2007 07:26 AM
Vibration henri TJ Wrangler Technical Forum 13 04-13-2005 07:25 AM
