94 yj transfer case problems - JeepForum.com
post #1 of 10 Old 05-27-2010, 01:07 PM Thread Starter
kiitanak
hey guys , just wanna say, LUV THIS FORUM.... anyways,
i have an issues when shifting into 4L when im going to go offroading. i can shift into 4H and N, but when i try to shift in 4L, nothing, seems as if its in N. Now the tricky thing about this is its not all the time. sometimes in will snap in, but so far, its been awhile since ive been able to shift it into 4L. seems as if theres a wall blocking me to shift the lever into 4L.
any ideas??? plz help.
kiitanak is offline
post #2 of 10 Old 05-27-2010, 01:12 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Do you have a body lift? Maybe the shifter is hitting the tub near the 4LO position.
Here you can see it gets pretty close, add in the 2 shift boots & things get really cozy in there!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 10 Old 05-27-2010, 01:13 PM
lieke730
Try the shift linkage underneath. You should be able to move it from 4h to 4l to 2 manually. I know on mine I had to manually take it out of 4 low, I played with it and played with it. See if you can't lube it up or work it into low.
lieke730 is offline
post #4 of 10 Old 05-27-2010, 01:27 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I would try adjusting the shift linkage first, seems like its ever so slightly out of adjustment where you can sometimes get it into 4L.
Just to cover all bases, you are shifting into 4L while crawling at 2-3mph with the transmission in neutral?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 10 Old 05-27-2010, 01:28 PM Thread Starter
kiitanak
completely stock, no body lifts
kiitanak is offline
post #6 of 10 Old 05-27-2010, 01:36 PM Thread Starter
kiitanak
yep, like i said, seems as if theres a wall blocking me into shifting into 4L.
thnxs!! i will diffently try that!
kiitanak is offline
post #7 of 10 Old 05-30-2010, 04:21 PM Thread Starter
kiitanak
so its sunday and im fixing this issuse, reading my haynes manuel, and im finding out theres NO LOCK BOLT on the TRUNNION!!! would anybody know the size of this bolt???
ALSO....
would anybody know how to fix a loose stick shift. pretty much in all gears, 1-5 plus R, it feels kinda likes in on N, any ideas..???
thnxs in advance guys
kiitanak is offline
post #8 of 10 Old 05-30-2010, 04:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
ALSO....
I can't help with the bolt info....sorry.
This may help on the sloppy shifter.
http://www.jeepforum.com/forum/f12/s...hifter-513891/
Max
Mean Max is offline
post #9 of 10 Old 05-31-2010, 08:16 AM Thread Starter
kiitanak
thnxs MAX!!! trying that out today, this morning!!! thnxs again
kiitanak is offline
post #10 of 10 Old 06-03-2010, 12:04 AM Thread Starter
kiitanak
it was the shift linkege 4L here we come
kiitanak is offline
Transfer My Old Paid Account To My New One IWantMyMTZ JeepForum Announcements 1 07-22-2008 08:56 AM
Problems with JF NewdRiver_ JeepForum Announcements 12 07-01-2007 09:38 AM
Having Problems with JF? Try This... dakuda JeepForum Announcements 1 12-22-2005 06:13 AM
problems LOCKED UP JeepForum Announcements 6 09-03-2003 11:06 AM
