94 YJ speedo - JeepForum.com
post #1 of 2 Old 06-20-2001, 10:36 PM Thread Starter
bonehead99
bonehead99's Avatar
94 YJ speedo
I am going to install 31x10.50-15's. I was told by a local shop my speedo won't be off until 65mph, but I used a mph calculator and it said at 55 I would be doing 63...which is true? also can anyone tell me what gears are in the rear end(they are still stock) and how much of a difference in rpms will taller tires make?
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 2 Old 06-21-2001, 01:17 AM
jpwranglr9
well, what you have in the rear depends if you have an auto or manual and if you have a 4 or 6. if you have a 6 with a manual then you have 3.07, if its a 4 with an manual it is 4.10. (or 4.11 cant quite rember). Look on the little tage on the axle to see what it is exactly. Running 31's wont make your spedo to far off. i think i was 5-8% off. what you can do is when you get the tires on, go drive exactly 10 miles measured on the highway (this gives better measurments but you can do 1, or 5 or whatever) and check how far your jeep says it is on the trip guage.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
Take a speedo gear <> Leave a speedo gear spokanistan TJ Wrangler Technical Forum 1406 11-10-2017 01:15 PM
Changed speedo gear-Now Speedo no worky BoatCop TJ Wrangler Technical Forum 7 08-07-2011 05:37 PM
Speedo Question (not your average speedo queston though) EJames1226 YJ Wrangler Technical Forum 3 05-01-2008 10:51 PM
speedo goes out??? help datree TJ Wrangler Technical Forum 1 05-15-2003 09:14 AM
