94 yj shackles - JeepForum.com
post #1 of 6 Old 06-25-2001, 10:31 AM Thread Starter
bonehead99
bonehead99's Avatar
94 yj shackles
I have the fronts installed, now how can I get the bolts out of the rear shackles? The gas tank sits to close to the frame to remove any off the bolts.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 6 Old 06-25-2001, 06:43 PM
mikeyjph
Use an open ended wrench on the inside nut(the one closest to the gas tank) and a socket on the other side.
mikeyjph is offline
post #3 of 6 Old 06-25-2001, 09:53 PM
jpwranglr9
are u having trouble pulling out the bolt??? if so you have to move the tank. you dont have to take it out but just move it enough to the side. what you do it place a jack under the tank. then unbolt the bolts along the rear fram rale that holds up the skidplate. then there are 2 or three that bolts the front of the skidplate to the center crossmember. undo this and the tank should be loos. drop the tank down just slightly and push it over to the side. you just want to move it enough to ge the bolt out above the tank. if you dont have a body lift the tank should move quite a bit. this will let you take the bolt out. then when you put it back in, put the bolt from the outside in. make sure the bolt isnt to long. (if you are using stock bolts with stock shackles you will be ok. but if not, make sure you have pleanty of room or it will puncture the tank on the driver side) Good luck.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #4 of 6 Old 06-25-2001, 10:37 PM
jpwranglr9
i just read your other question about the shackel mounting dirrection. Who did you buy them from and do you know who maked them? there is a big difference. i had 1.25 warior shackles on my jeep. the front and rear are different. the front had the center block in the center. the rear had it offset to one side. the offset is there to clear the frame. the rear hanger is in the center frame and the front is on the bottom of the frame. so when mounting the front it makes no difference, but if there is a difference, mount the larger space on the frame. this will allow the shackle to clear the frame during its cycle. the other way around, then you may hit the center brace of the shackle on the frame at full compression. the rear is the same way.
post #5 of 6 Old 06-25-2001, 11:24 PM
osburn
osburn's Avatar
WHOA THERE!!! I'm amazed how often this question gets asked. You DO NOT have to mess with the fuel tank. Simply take off the nut, then the outside section of the shackle, then work the outter half of the bushing out. Once that part of the bushing is out, you will have enough room to manuever the bolt out.
Oh, and put the bolt in the other way when you put it back together so you don't have to go thru this again.
Matt Osburn
Score 1032
osburn is offline
post #6 of 6 Old 06-26-2001, 06:32 AM Thread Starter
bonehead99
bonehead99's Avatar
thanks for everyones help!! I now have the rear shackles on and my 31's were installed last night. My next problem I think is the length of the shocks. A local shop said I need 19.5" because thats 2" longer than stock(which he said is 17.5) Is this right?
All about shackles Brandon_YJ YJ Wrangler Technical Forum 98 02-03-2014 08:35 AM
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 06:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 12:30 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 02:28 PM
