Quantcast 94 YJ Restoration ...PICS !!! - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94 YJ Restoration ...PICS !!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 09-07-2006, 08:21 AM   #91
ghiradelli777
getting a hold of a newer frame might be better in the long run unless you are going to dip the enitre inside and outside in POR-15....but i dont think that would be cost effective or worth all the work...
i would just switch for a newer frame from the junkyard
my .02
1992 YJ Sport White 4.3 swap in progress
Eagle Scout Jeep Owner
ghiradelli777 is offline   Reply With Quote
Old 09-07-2006, 08:45 AM   #92
theboxman71
Originally Posted by Pullie
must be something with that color
I did that sort of job on my 1992 YJ a year ago. it took me 6 months from start till finish
I also had the holes in the frame and the body.
i'll post a link with the pictures, on this moment the pics are on the Dutch Jeepforum
http://www.jeepforum.nl/forum/index.php?showtopic=1377&st=15
good luck with the project!!
Hey...how did u repair the frame holes?
THX
theboxman71 is offline   Reply With Quote
Old 09-07-2006, 09:26 AM   #93
theboxman71
my .02
I doubt I'll find a frame in Canada without similar probs...
I'm just gonna oil the inside of the frame and por-15 the outside, that'll delay the inevitable for a little while
1994 Jeep YJ SE Sport-UNDER CONSTRUCTION!!!
See it here
http://www.jeepforum.com/forum/showthread.php?t=303516
Old 09-07-2006, 09:27 AM   #94
theboxman71
when the frame fails....gotta get the tube frame from Quad
See it here
Old 09-08-2006, 12:46 AM   #95
Pullie
THX
I only had the holes in the rear around the schackle bushings. I took a piece of 4mm sheet metal with a hole for the bushing and welded it in the frame. i'll see if I have some pictures
Pullie is offline   Reply With Quote
Old 09-08-2006, 10:00 AM   #96
theboxman71
excellent....thats what i had in mind...
pics would be great...
See it here
Old 09-10-2006, 03:19 PM   #97
Pullie
been looking all around my PC but can't find any pictures of the fab work on the frame. just get all te rust grinded out, clean the holes and make sure you have enough parent material to weld on and get some 3 or 4 mm thick sheetmetal to make the inserts and start welding!!
good luck!!
Old 09-12-2006, 07:13 AM   #98
theboxman71
good luck!!
Thanks for the info...that's what I'll be doing....
Did u do anything to the inside of the frame?
I am going to spray oil inside and plug up the holes....anyone else have experience with this?
See it here
Old 09-12-2006, 10:28 AM   #99
crosschecker
1995 XJ Cherokee
Yep, I just rebuilt the whole back box channel, the last 20" of it because there just wasn't enough metal to weld to. I cut each channel off and made new channel and tied the two together with a 2" x 4" bumper.
crosschecker is offline   Reply With Quote
Old 09-12-2006, 11:59 AM   #100
theboxman71
cool...got any pics?
See it here
Old 09-12-2006, 12:37 PM   #101
crosschecker
1995 XJ Cherokee
I can get some tonight. Getting them on here may be another story.
Old 09-17-2006, 06:28 PM   #102
theboxman71
Update!!!
Got some more work done today.
Removed steering column, disconncted everyhing from my firewall; electrical, power steering booster, clutch fluid resevoir, so on...
My next move is to get my buddys to help me lift the tub over the shifters
Can't wait to get at the frame
THX for looking...
See it here
Old 09-28-2006, 11:02 PM   #103
theboxman71
Finally got my welder, cause i'll need it... was 150 bucks off, so I grabbed it.
Now any advice on how to practice with this before I fix my frame issues?
Any other help from u pros would be great.
This is a wire feed mig welder which can be used with or without gas.
Thx guys...
the specs...-
70 A wire-feed welder
Infinite wire speed control
High-efficiency transformer
Includes wire-feed welder, gas regulator, gas hose, two hose clamps, welding shield, one spool of flux-core wire, hammer/brush, quick-start guide and instruction manual
Uses MIG (gas) or flux-core (gasless) wires
Heat selection dial with four settings
See it here
Old 09-29-2006, 10:18 AM   #104
ghiradelli777
sorry forgot about you location
also you can buy replacement floor pans that you can weld into place so you dont have tt worry about fabricating one
Old 09-29-2006, 10:50 AM   #105
bombadillo
that is an ungodly amount of rust! My hat is off to you and the work you're doing!
93 white wrangler, warn rock crawler bumper w/guard, custom rear bumper, warn lights, superlift 3.5" suspension lift, Lift shackles rear, (Soon to be front too) crappy shocks, 32x11.50 BFG MT's on eagle alloy 10 hole wheels, Swaybars and track bars removed. H4 conversion headlights, Hi-Lift ghetto mounted, Header from above ^^ and other goodies.
bombadillo is offline   Reply With Quote
Glock Forum
