Quantcast 94 YJ Restoration ...PICS !!! - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94 YJ Restoration ...PICS !!!
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 11-14-2006, 03:09 PM   #151
theboxman71
Originally Posted by atomicmoose
I hope that this approach works. .
Hey me too...
all the old metal is solid, just below the bushing opening is where there is some holes...
it will be tacked ...and tacked...and tacked...I'll definately over do it to be sure...
1994 Jeep YJ SE Sport-UNDER CONSTRUCTION!!!
See it here
http://www.jeepforum.com/forum/showthread.php?t=303516
theboxman71 is offline   Reply With Quote
Old 11-16-2006, 03:07 PM   #152
JoonHoss
1968 C101
can't seem to find how to subscribe to a thread, so I'll just post, and follow it that way.
big project, and I am (so far) impressed
keep it up!
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Old 11-16-2006, 05:48 PM   #153
jimmylev
keep it up!
Hoss
THREAD TOOLS
j
Old accountants don't die, they just lose their balance
jimmylev is offline   Reply With Quote
Old 11-16-2006, 05:57 PM   #154
JoonHoss
1968 C101
Originally Posted by jimmylev
THREAD TOOLS
j
Thank-you
Old 11-16-2006, 07:14 PM   #155
theboxman71
keep it up!
Hoss
Thanks alot...the encouragement is great...
LARGE project yes...learning as I go!!!
See it here
Old 11-16-2006, 10:21 PM   #156
learfxr
Wow, just stumbled across your thread. You have a large project going. I thought my YJ was a hand full, but I'm not fighting any rust. I bought a 89 with the engine and trans pulled out. I put in a TF727 and NP208. I parted a Wagoneer for my trans and decided to keep the axles also. Every time I work on a part of the project something else is messed up. I'm only about 1/2 way along with my build up. I'm kicking myself for selling my little welder now.
learfxr is offline   Reply With Quote
Old 11-17-2006, 08:57 PM   #157
theboxman71
Over 10000 views...I'm flattered, thx for looking...!!!
See it here
Old 11-17-2006, 11:35 PM   #158
howellru
Impressive undertaking BoxMan. Got my first Jeep six months ago and am stumbling my through what-soon-may be a light restoration. Already added new front hub assemblies, radiator, brakes and A/C. Currently struggling with sputtering MotorCraft carb.
And it's my daily ride!
Sorry, didn't mean to ramble.
Back to BoxMan's Baby Blue.
Really look forward to watching your project evolve, BoxMan. I'm going to try and mirror you when you cover one of my needed corrections. And, keep posting those pics. They're inspiring to a Jeep greenhorn like me.
Rock on!
Welcome to my midlife crisis. ;)
'89 YJ Wrangler, 4.2L, MC2100 Nutted Carburator
howellru is offline   Reply With Quote
Old 11-18-2006, 12:16 AM   #159
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
had exactly the same problem on mine, and basically did what you did, frame off rebuild....
a few points though, drill a 1/2 inch hole on the underside of each frame rail at the rear, at the lowest point, providing a drain.
i welded 1/8" plate all the way around, top, sides and bottom, then drilled out for the bushings witha hoes saw, the welded in the bushings. luckily the inside diameter is a stock size tubing...
you will have to use some big grade 5 washers to space out the shackles where they meet the springs, be sure and use the shackles that are bolted together so you can do this, the welded ones wont work.
after doing all that, aswell as welding a support on for the steering box, it broke, due to it being very badly rusted o nthe inside of the frame......duh!
i am now doing what i should have done the first time, got a rust free frame and starting all over again.... hope you have better luck than i did!
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Old 11-18-2006, 12:32 PM   #160
theboxman71
Rock on!
Thank for the nice words!!!
See it here
Old 11-18-2006, 12:33 PM   #161
theboxman71
did it break near the steering box? Damn, I hope that doesnt happen
See it here
Old 11-18-2006, 12:34 PM   #162
theboxman71
Welder Wannabe !!!!
See it here
Old 11-18-2006, 12:35 PM   #163
theboxman71
More pics of my crappy beads when I'm done!!!
See it here
Old 11-19-2006, 02:26 AM   #164
leftlanetruckin
XJ on 37's
yep, you guessed it! and to add to that, the outside part of the frmae had a brace welded to it.....just snapped the whole thing. me and scott (tomb raider) were at fulton,mo wheeling, and noticed whenever i turned the steering wheel, the frame moved! not good....
had to be cut back to the shock mount to get a solid piece to weld to...
there are more rust spots on the rear too, coming thru the por 15......... its basically scrap, all rusted from the inside. i would definately check the inside of the frame rails before reassembly, can't tell you an easy way to do it, but do it anyways. wouldnt want to see someone do the same screw up as me
http://www.jeepforum.com/forum/showthread.php?t=324622
Choose wisely!
Old 11-19-2006, 11:11 AM   #165
theboxman71
How hard do u drive her?
I'm not really planning to pound on her offroad, at least at the beginning...
I'm also gonna treat the inside,
If I get a few years out of her, I'll be happy!!!
Then I'll start on my Scrambler!!!
See it here
Glock Forum
