Quantcast 94 YJ Restoration ...PICS !!! - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94 YJ Restoration ...PICS !!!
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 11-09-2006, 12:57 PM   #136
Skeezer
I wish you all the best, that was just my suggestion. I've built 4 Jeeps from the frame up over the years, so your not talking to some part time wheeler who gets his kicks out of rebuilding four bangers to cruise around the mall parking lot on weekends.
Good luck on your venture.
2006 TJ Sport
1995 YJ
2007 JK Sahara Unlimited
www.GrassRootsJeepClub.com
www.GrassRootsJeepClub.proboards80.com
Skeezer is offline   Reply With Quote
Old 11-09-2006, 02:20 PM   #137
Super D
Wow you are a very lucky man. I started a project like yours but it was a '67 CJ-5.
Well then I got married then had the first child and quickly ran out of that green stuff and had to part it out. Now eight years later and two more kids I have finally got me another JEEP to start wrenching on. So best of luck to you and keep up the good work.
Super D is offline   Reply With Quote
Old 11-09-2006, 11:18 PM   #138
theboxman71
THX, u certainly have more experience than me, this is a learning experience for me, you know...live and learn...I've never done anything close to this before...the most is a brake job and shock replacement, that's about it.
I am gonna keep at this one cause I've come so far and the end is almost in site,
If it some how fails, I'll strip it down and start over, beats blowing all my cash on dope or booze and keeps me out of trouble...for now
Later...
1994 Jeep YJ SE Sport-UNDER CONSTRUCTION!!!
See it here
http://www.jeepforum.com/forum/showthread.php?t=303516
theboxman71 is offline   Reply With Quote
Old 11-09-2006, 11:19 PM   #139
theboxman71
LUCKY??? i donno about that
man, id love a 60's CJ to wrench on,
I think I'm gonna try a CJ-8 scrambler next
See it here
Old 11-12-2006, 01:04 PM   #140
theboxman71
new metal tacked over frame...
See it here
Old 11-12-2006, 01:05 PM   #141
theboxman71
Ugly weld beads...easy you welder dudes...its my first time
See it here
Old 11-12-2006, 01:07 PM   #142
theboxman71
more pics of new metal...
See it here
Old 11-12-2006, 01:11 PM   #143
theboxman71
It is nowhere near done yet...alot more beads to lay and a lot of grinding to make it pretty....
After all that...2 coats of POR-15 and maybe some herculiner over the whole frame....
Spray some oil inside and I can finally move on to the springs and shocks.
Thx for looking...
Later...
Here's a before and after comparison...
See it here
Old 11-12-2006, 08:40 PM   #144
theboxman71
I was thinking of putting a couple of bolts through everything just to give it more strength. any thoughts?
See it here
Old 11-13-2006, 06:45 AM   #145
atomicmoose
Just call me Moose
atomicmoose's Avatar
Have faith in your welds. More holes in the frame will only weaken it and give more entry points for water. Are you going fish plate the new metal to the old metal?
atomicmoose is offline   Reply With Quote
Old 11-13-2006, 03:52 PM   #146
theboxman71
I was thinking the same thing,
i guess i should fishplate the ends but the new metal is not flush with the old metal, if that makes sense.
See it here
Old 11-13-2006, 05:19 PM   #147
atomicmoose
Just call me Moose
Why is it not even? Did you not use the same gauge? I'm sure I linked you to Sentinal02's writup on his frame repair. You need to do something like that.
Old 11-13-2006, 06:20 PM   #148
crosschecker
1995 XJ Cherokee
The new metal is on top of the old metal, he did not cut away the old.
At least if you're not going to cut out the old rusty metal, you should weld your shackle bushing to your new metal.
crosschecker is offline   Reply With Quote
Old 11-13-2006, 07:12 PM   #149
theboxman71
EXactly bud....I'm welding the new metal around the bushing...yes...
Metal is not even because the new metal is on top the old hence, not even..
the old did not need to be cut away, lots of good metal there, I am just basically covering the holes and strengthening things. all old metal is covered both sides with POR-15
thx for looking...
See it here
Old 11-14-2006, 08:44 AM   #150
atomicmoose
Just call me Moose
I hope that this approach works. If it were me, I would have cut the old stuff out. With that said, I would definitely run the new metal to where the frame is solid and tack it really good.
Glock Forum
