94 yj pros and cons? - JeepForum.com
post #1 of 22 Old 11-10-2007, 07:15 PM Thread Starter
beachrusso
2010 JK Wrangler
Looking at a 94 yj with the I6 and a 5 speed manual trans. Small lift with 31's, only showing 110000 on the dash with AC. I need to know what is good and bad about the motor and trans combo I am looking at. Thanks I just want to have a solid platform to start my build. My build goal is being able to ride to the trails hit some hills and drive it back home.
beachrusso is offline
post #2 of 22 Old 11-10-2007, 07:21 PM
jeeepguy
jeeepguy's Avatar
You have one of the best build platforms you can get.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #3 of 22 Old 11-10-2007, 07:35 PM
swedishdwarf
swedishdwarf's Avatar
Yep. That's the same powertrain I have and I love it.
You can't teach an old dogma new tricks.
swedishdwarf is offline
post #4 of 22 Old 11-10-2007, 09:52 PM
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
I have an I4 and an AX-5. I would love to swap to an I6 and an AX-15. Great powertrain and EFI, you should have a blast.
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline
post #5 of 22 Old 11-10-2007, 11:44 PM
swedishdwarf
I just noticed it has AC. You should buy it. The only stronger indication that you should buy it would be a factory hard top.
post #6 of 22 Old 11-11-2007, 05:50 AM
Nelliebelle7
He's from South Carolina. Why would he want a hard top?
Nelliebelle7 is offline
post #7 of 22 Old 11-11-2007, 09:06 AM
crb577
That's a great place to start. the swap to 4 cyl front D30 and rear 8.8 with 4.10's is cheap and easy and an even better place to start. with only 110000 on the clock that's nothing for these inline 6's i've seen them properly maintained much higher than that.
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #8 of 22 Old 11-11-2007, 05:08 PM
Cobra Jeep
Yep, the 91-95 YJ's with the 4.0 are the best years. I have a 93 and have 226K on it and still going every day.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #9 of 22 Old 11-11-2007, 06:10 PM
Berb_15
Definitely go for it, I had a 4cyl and ended up buying a new yj with an inline 6 a year later and it's definitely worth it
"Lock tite!!
Mans best friend cuz your dog won't keep your jeep from falling apart."
Berb_15 is offline
post #10 of 22 Old 11-11-2007, 07:37 PM
swedishdwarf
Because a factory hardtop almost doubles the resale value. Around here it does, anyway.
post #11 of 22 Old 11-11-2007, 07:54 PM
pwoens
pwoens's Avatar
best year out there love mine...kind of hard to find in good shape with I6 and 5 spd.
<>< Turn your face to the Son, and the shadows fall behind you
94 YJ 4.0L, BDS 4 1/2", 1" BL, 33 x 12.50, SYE & Tom Woods drive shaft, 8.8 w/lsd, Aussie Locker front, T & T Phantom tube fenders, Warn rock sliders custom cut, TJ rear flares and Fuel filler, Warn M8000, Custom front & rear bumpers w/swing out, bad apple diff guards, Dual 1400 amp Kinetic Energy batteries, HO alternator, 2 guage comp wires, VIAIR 450c, WRX seats, and way too much more to list. No end in sight!!
pwoens is offline
post #12 of 22 Old 11-11-2007, 08:01 PM
jeeepguy
jeeepguy's Avatar
Besides... doesn't it rain and snow in SC?
I wouldn't give up my hardtop for anything.
Doug Patton
Revelation 13:16-18
Think about it...
jeeepguy is offline
post #13 of 22 Old 11-11-2007, 09:46 PM
Jesse-James
Jesse-James's Avatar
1989 XJ Cherokee
It's quiet, holds in heat, it's quiet, makes the AC more efficient, it's quiet.....
Live in SE WI? ----->
Jesse-James is offline
post #14 of 22 Old 11-11-2007, 10:39 PM
cooltc2004
Yeah, all that, and its quiet...
1988 Jeep Wrangler YJ
cooltc2004 is offline
post #15 of 22 Old 11-12-2007, 04:42 AM
Nelliebelle7
Doubles? I think not. Unless you get one for $500.AC? QUIET? Pansy jeepers. Might as well get a civic.LOL
4.2 Pros/Cons JakeMurray24 YJ Wrangler Technical Forum 19 06-05-2009 08:06 PM
Pros and cons of 4cy -vs- 6cy ut1031 YJ Wrangler Technical Forum 33 02-28-2007 12:52 PM
between these two, the pros and cons wrangler2007 TJ Wrangler Technical Forum 22 02-18-2007 04:42 PM
Pros Vs. Cons of RE and Nth JeepRocks86 TJ Wrangler Technical Forum 6 12-22-2006 08:16 AM
Keep '98 TJ or Buy '06 TJ? Pros & Cons BLAINE TJ Wrangler Technical Forum 12 02-22-2006 05:14 PM
