94 YJ No dash lights. Please help! - Page 2 - JeepForum.com
post #16 of 22 Old 04-21-2013, 10:17 PM
ign_cas
I had this problem when I first got my jeep. I checked the fuses and the were good. My fuse went in good, I thought. But it ended up being that it wouldn't go in all the way. So I had to push it in more than normal and they ended up working.
ign_cas is offline
post #17 of 22 Old 04-22-2013, 06:29 AM
Que89YJ
The orange wire is your feed for the lights. Check it with the lights on. Maybe this diagram will help. The other one is a functional flow. This should make it more clear.
Que89YJ is offline
post #18 of 22 Old 05-28-2013, 09:57 AM Thread Starter
4-wheelin
Well still having the issue but was driving it last night over some rough terrain and they all of a sudden came on then went off. That tells me there is a short somewhere in the harness. GREAT!!!
4-wheelin is offline
post #19 of 22 Old 05-28-2013, 03:59 PM
Que89YJ
not a short. our its an open and should be easy to find.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #20 of 22 Old 05-28-2013, 05:04 PM
idaholtby
Yep, you have a poor connection at some point. Start wiggling wires and connectors to see if you can narrow this problem down.
idaholtby is offline
post #21 of 22 Old 05-29-2013, 07:29 AM
Firefyter-Emt
My first place to start looking is the dimmer switch. I have seen many melted switches over the years. If you have factory interior lights, can they be switched on from the dimmer switch still?
Firefyter-Emt is offline
post #22 of 22 Old 05-29-2013, 09:05 PM Thread Starter
4-wheelin
Well I be dang!
Seems there is a bad connection at the dimmer wheel.
Can't believe all this time that's all it was. Thanks for all the help on this forever long issue. Now onto the next one...
