94 YJ with Major Vibration - JeepForum.com
post #1 of 9 Old 05-09-2010, 10:00 PM Thread Starter
ChuckTe
Ok, I had the clutch replaced a couple of months ago. I don't know if it's related but I recently got a major vibration in and out of gear. Get's worse when slowing down to around 10 MPH. I pulled off the driveline and the U-Joints are in good shape. The tranny, transfer case and motor mounts all look good. Could it be the rearend? My pinion seal has been leaking for about a month but my fluid level is fine because I've been keeping an eye on it. I pulled the dif cover off and everything is tight but I noticed the spider gears have some gouges in the teeth.
Any ideas?
ChuckTe is offline
post #2 of 9 Old 05-10-2010, 12:04 AM
MJMPC
Where do you think the vibs are comming from ft middle or back of jeep?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 9 Old 05-11-2010, 07:41 AM Thread Starter
ChuckTe
It's coming from the back
ChuckTe is offline
post #4 of 9 Old 05-11-2010, 07:49 AM
Louie4
What's your pinion angle look like? Do you have a t-case drop kit or SYE? Have you checked your u-joints on the rear driveshaft?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 9 Old 05-11-2010, 07:57 AM Thread Starter
ChuckTe
My pinion angle is fine. The first thing I checked was the u-joints and motor and tranny mounts. I have been running my current setup for about 5 years. The vibration just started all of a sudden.
ChuckTe is offline
post #6 of 9 Old 05-11-2010, 10:11 AM
pasinbuy
Since you think it is coming from the rear. Jack up the rear tires and chock the front tires.
Put it in gear and test fo the vibration.
Check the tires for roundness and out of balance. From what you are describing you might have hit something that put a knot or placed your tires out of round. Who knows?
pasinbuy is offline
post #7 of 9 Old 05-11-2010, 10:19 AM Thread Starter
ChuckTe
I'll check that out. Thanks
ChuckTe is offline
post #8 of 9 Old 05-11-2010, 10:22 AM
MJMPC
Check your pinion nut see if it is loose.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #9 of 9 Old 05-17-2010, 08:10 AM Thread Starter
ChuckTe
So this weekend I crawled under the Jeep with the rearend jacked up and spun the tires. No wobbles that I could notice but I did notice that I can move the 2 smaller spider gears around a little. They wiggle quit a bit and every tooth has some big chunks missing. I can also spin the shaft that holds them in. I checked the set screw that holds the pin in and it's tight. I can slide the shaft up and down a little also.
Could this be causing vibration? I read in a couple places that if that shaft is moving around the carrier is pretty much shot and should be replaced.
ChuckTe is offline
major vibration after 8.8 and SYE conversion postaldave YJ Wrangler Technical Forum 6 03-15-2010 09:17 AM
just bought a 97 tj w/33" toyos, major vibration 35-50 rugerdog TJ Wrangler Technical Forum 7 07-05-2009 04:49 PM
2 major Issues - vibration - transmission? Gearhead22 YJ Wrangler Technical Forum 8 06-26-2008 04:26 PM
Major Vibration Help a Brother Out Posey204 YJ Wrangler Technical Forum 12 02-21-2008 05:49 PM
Major front end vibration need help!! rustywrangler YJ Wrangler Technical Forum 15 11-13-2005 08:18 AM
