94 yj leaking axle seal Help - JeepForum.com
post #1 of 8 Old 04-30-2005, 07:14 AM Thread Starter
turbotempo85
This is the first thing I have had to do to my YJ since purchasing it. I need a little help in how to go about changing the passenger side front axle seal. It has just started to leak from the axle right behind the front u-joint. Stock front axle 115,000 mile 6 cyl if any of that info is actually needed. Main question is how to go about doing it and wondering what else I should prepare my self to replace or fix along the way. Any special tools required? Any help would be great and I can reply with more info if needed. Thanks TJ
turbotempo85 is offline
post #2 of 8 Old 04-30-2005, 10:07 AM
lilfoot
I found a thread with some good information
http://jeepforum.com/forum/showthrea...ight=axle+seal
I like Sentinal02's tip for replacing the passenger side without removing the carrier. It will save a lot of trouble.
When removing the axle you will need to remove the caliper and hub and axle assembly--you should not have to seperate the axle from the hub assembly as it will come out in one piece.
You will need a 13 MM 12 point socket to remove the bolts for the hub (for some reason mine had a 14 MM??)
Check the other post out, it should help.
Scott
Scott W
Used to have a 1988 YJ Laredo
6 Cyl w/5spd, 3" Lift, 31" tires and Howell EFI
lilfoot is offline
post #3 of 8 Old 04-30-2005, 10:17 AM
JeepDrivr93
JeepDrivr93's Avatar
I am in the same boat with 115,000 miles and a 4 cyl. Hope this isnt too difficult.
Jeepless...
1998 Cherokee Classic - SOLD
1993 YJ - SOLD :(
JeepDrivr93 is offline
post #4 of 8 Old 05-01-2005, 02:17 PM
condoor
When you replace this seal note the surface of your axle shaft where it makes contact with the seal. Mine was scored pretty bad and continued to leak even with the new seal. Good opportunity to upgrade to ABS shafts with the 297x u-joints.
condoor is offline
post #5 of 8 Old 05-02-2005, 07:27 AM
Jpman94
Scott
Yep, read this. I've answered this before. Although if I ever do another one I'm going to try Sentianl02's suggestion. It sounds like it would work pretty sweet. I was in the diff anyway when I did mine so I did it the way I wrote up and it worked pretty good.
Jpman94 is offline
post #6 of 8 Old 05-02-2005, 06:28 PM
Oakey
Oakey's Avatar
If it is a light leak... Just add a (2) small cap fulls of Dot 4 brake fluid to your diff... This will cause the seals to expand... Give it a couple days to work.... Ive done this to couple JEEPs and havent had one start leaking again....
L8R,
Shane Hill
a.k.a. -- O A K E Y --
1991 YJ Wrangler Type S
My Mods: "Too Much for SOME & Not Enough for OTHERS!"
Oakey is offline
post #7 of 8 Old 04-11-2007, 05:05 PM
Think
Think's Avatar
L8R,
sorry for resurrecting an old thread, but I have to ask: will this actually work? or it just an old jeep wives' tale?
seems like an easy fix to a crap problem.
edit: this is a crap problem I am having.
95 YJ 2.5 litre + broke student with a TON of debt = slightly more than stock Jeep that is rusting out
I'm not a vegetarian because I like animals, I'm a vegetarian because I hate plants
Think is offline
post #8 of 8 Old 04-12-2007, 11:27 AM
Think
Think's Avatar
bumpity bump bump
Think is offline
Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? MWguy101 YJ Wrangler Technical Forum 21 03-01-2012 11:08 AM
Axle Seal Leaking/07 JK oaklane JK Wrangler Technical Forum 20 08-09-2010 08:05 AM
Axle seal? leaking axle fluid from u-joint ZeroGravity YJ Wrangler Technical Forum 21 02-11-2009 10:10 AM
Leaking axle seal...again! fyrdriver YJ Wrangler Technical Forum 3 11-03-2008 08:26 AM
Axle seal leaking Kajunjeepn TJ Wrangler Technical Forum 1 06-08-2006 03:31 PM
