94 YJ fuel lines at tank - JeepForum.com
post #1 of 5 Old 07-27-2010, 04:01 PM Thread Starter
bryanmc
Well... The rubber lines that come off the top of the fuel tank finally started leaking. After much fighting, I finally got the tank down and got the 2 larger ones loose. I wonder who the idiot was who designed that flat rubber grommet thing that the lines run through between the body and crossmember?
Anyway, here's my problem. I have both of them off and had originally thought they were different sizes... nope, both 5/16. Now I don't know which one goes where.
Anybody know?
Appreciate the help.
bryanmc is offline
post #2 of 5 Old 07-27-2010, 04:24 PM
pasinbuy
The fuel line hoses are a dealer only item. I am not familiar if they are available after market. One of the hoses is a larger end than the hose itself. If the PO replaced it with a standard hose that is why it is leaking.
Pain in the neck I know, hopefully your dealer has it the hoses stock. I screwed up and forced a hose on the line to get by, but I do know that I have to replace it before it leaks.. My mistake.
pasinbuy is offline
post #3 of 5 Old 07-27-2010, 04:42 PM Thread Starter
bryanmc
Well....
Just got off the phone with the dealer. The supply line they can get, the return line is no longer available. Hopefully the supply is the one that has the bigger end on it and I can get by with regular 5/16 for the other one. Now if I can just figure out which goes where....
bryanmc is offline
post #4 of 5 Old 07-27-2010, 04:54 PM
FLMudder
I just did mine a couple days ago, and i just ran 3/8 high pressure line on the supply(one towards the front of the tank) all the way to the fuel filter. Then i ran 5/16 for the return (towards the back of the tank) to the metal line.
FLMudder is offline
post #5 of 5 Old 07-27-2010, 05:09 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Maybe this will help, with pics.....
http://www.jeepforum.com/forum/f12/h...emoval-981049/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
87 YJ fuel tank and lines running to fuel pump 87yjjeep YJ Wrangler Technical Forum 2 05-27-2007 03:07 PM
'04 Gas Tank Fuel Lines... thejafe TJ Wrangler Technical Forum 2 04-14-2007 11:35 PM
Anyone have a pic of the fuel lines,etc on top of gas tank? wwiihistory YJ Wrangler Technical Forum 11 09-24-2006 06:27 AM
Need braided steel fuel lines (from tank to frame lines) drew2000 YJ Wrangler Technical Forum 4 06-18-2006 08:38 AM
Need fuel lines and tank kg6mti YJ Wrangler Technical Forum 1 11-21-2004 09:08 PM
