94 yj Frame rust by rear shackle. - JeepForum.com
post #1 of 8 Old 05-29-2012, 09:45 AM Thread Starter
JeepJon15
So i started hearing a squeak/creek from the rear end last week. After a quick inspection, i found the frame where the rear drivers side shackle bolts on is rusting out.
Hoping to get some advise on the proper way to repair this. Should i simply cut out the old rust and get one of the pre-cut frame re-enforcement kits I've seen around here? This seems like the easiest method to me, but i've never done frame repairs before, so im pretty clueless.
I know one of the POs of this particular rig already patched the rear frame on both sides, and it looks like he did a good job. The rust thats plaguing her now is a couple inches behind the patch job.
Heres a visual, let me know if you need a better pic.
Thanks
Jon.
*In the picture you can kind of see the other spot of rust. About the size of a quarter on the bottom of the frame.
JeepJon15 is offline
post #2 of 8 Old 05-29-2012, 09:49 AM
jbolty
jbolty's Avatar
The pre cut patches are a good solution but before doing anything I would inspect the remainder of the frame and perhaps consider a full swap.
jbolty is offline
post #3 of 8 Old 05-29-2012, 09:59 AM Thread Starter
JeepJon15
I took a screwdriver to the rest of the frame, that rear corner is the only problem area i've come across. Everything else looks pretty sound.
I hope a full swap isnt necessary for such a small area.
post #4 of 8 Old 05-29-2012, 10:12 AM Thread Starter
JeepJon15
Here is another pic, slightly different angle...
post #5 of 8 Old 05-29-2012, 10:13 AM Thread Starter
JeepJon15
I am going to work now. I'll be back this evening. Thanks in advance for any advice!
post #6 of 8 Old 05-29-2012, 11:17 AM
firefighter315
This is what my passenger rear looked like. I opted for the Auto Rust Technicians pre-fabbed pieces. It is a common problem and most either opt for using the ART parts or cutting/piecing together their own. You can see what I did with mine beginning with post #4 in my build thread if you like. (too many pics to post here)
My YJ Build Thread
firefighter315 is offline
post #7 of 8 Old 05-29-2012, 02:31 PM
jgrubb
I had the same problem on mine, welded a 8 inch steel plate along each side, grinded the rust off and sealed some of the frame holes so water wouldnt pool in there anymore. Had the jeep balanced and aligned after that and now rides great
jgrubb is offline
post #8 of 8 Old 05-29-2012, 05:54 PM Thread Starter
JeepJon15
Awesome, thanks for the input guys. Thats what i was hoping to hear.
Firefighter, i'll definatly check out your thread, hope to get to fixing it this weekend
Untill then i'll be driving her daily hah.
frame repair , rust repair , shackles , YJ
How I fixed the rear frame rust by the shackles on my YJ 0llllll0 YJ Wrangler Technical Forum 18 07-27-2013 01:40 PM
anyone have frame mount rear shackle tabs? aalbinger TJ Wrangler Technical Forum 0 06-09-2010 10:29 PM
Frame Rotted at Left Rear Forward Shackle dubbletime YJ Wrangler Technical Forum 7 01-26-2009 08:28 PM
Rust on Rear frame - 94 YJ ShaneS YJ Wrangler Technical Forum 16 05-08-2007 12:16 PM
Rusted Rear Frame/Shackle mounts runnwild1 YJ Wrangler Technical Forum 3 07-24-2003 10:36 AM
