94 Yj Engine trouble - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94 Yj Engine trouble
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-30-2015, 11:35 PM   #1
94Rape-J
Hey, I blew the engine out of my 94 Yj and found a replacement. A few things confuse me about the new engine though. It is a 4.0L just like the original but it was rebuilt and has roughly 65,000 miles on it. also the casting number indicates that it was no older than 1991 but had been fitted with throttle body injection which confused me, why would the previous owner get rid of the MPI fuel rail system that came out in that year for a less efficient TBI system. so i had the engine installed and fitted with a Manifold with MPI but now that it has been swapped out the, new engine runs gutless with hardly any horsepower and idles low with an occasional jump in Rpm. On the highway i can't even use 5th gear as it just boggs and drops in speed. Any insight helps.
94Rape-J is offline   Reply With Quote Quick reply to this message
Unread 03-31-2015, 05:18 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I think my first move would be a compression test just to be sure it isn't a failed rebuild. A gent on another forum only has 50K on his and one cylinder has dropped out to 60 psi with real low 120's compression in the rest.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 03-31-2015, 05:30 AM   #3
Que89YJ
There are a bunch of things it could be. Fuel, sensors, etc. It has no essential difference if it had the 91 with the HO engine. I would bet something got screwed up in the swap. Mike has the right idea in starting with compression, but I would hope who ever swapped it in for you would have checked before doing it.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 03-31-2015, 02:41 PM   #4
94Rape-J
Well initially i had hoped it was something as simple as fuel because what was left in the tank had been sitting for a while, so i added some supreme fuel and drove it with little improvement, also today I started it and noticed that the oil pressure gage was maxing out. Super disappointing.
Unread 03-31-2015, 03:39 PM   #5
Que89YJ
Check out the sensor and wire to it. You still might be ok.
Unread 04-08-2015, 12:58 PM   #6
94Rape-J
Hey, so my mechanic checked the timing and at top dead center the engine ran like crap. so he had the idea to set it ahead a little bit and th eengine now runs awesome! It runs nice and torqy as it should, my only concern now is what might come from running my engine with the timing chain slightly out of adjustment?? Also the oil pressure guage is still maxed out when i start the jeep, whats the best process of elimination to identify that problem??
Unread 04-08-2015, 07:05 PM   #7
Que89YJ
nothing at all.
Unread 04-08-2015, 08:29 PM   #8
Rebel442
Find a new mechanic, quickly.
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline   Reply With Quote Quick reply to this message
