94 yj clock and radio in dash fuse box... - JeepForum.com
post #1 of 10 Old 08-29-2011, 10:04 PM Thread Starter
ewalls
Help".....94 yj clock and radio in dash fuse box...
Got a wild hair and decided it was time to clean up some of the wiring in my jeep. I started to route a few things that were on my battery to the under dash fuse box instead. I noticed two outputs labeled clock and radio on the fuse box that have wires coming out going into a harness that seems to have been but by the previous owner. They seem to be extra available 12v sources but my question is where did they originally go to? Can one of you guys who has a 94 wrangler se take a look and let me know if you see something under there that would clear things up for me? Any info will be greatly appreciated thanks!!!!
"The tranny is so bad it feels like your shifting with a 2x4 in a 2 gal bucket of dog sh**"
ewalls is offline
post #2 of 10 Old 08-30-2011, 03:28 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by ewalls View Post
Got a wild hair and decided it was time to clean up some of the wiring in my jeep. I started to route a few things that were on my battery to the under dash fuse box instead. I noticed two outputs on the fuse box that have wires comi g ou going into a harness that seems to have been but by the previous owner. They seem to be extra available 12v sources but my question is where did they originally go to? Can one of you guys who has a 94 wrangler se take a look and let me know if you see something under there that would clear things up for me? Any info will be greatly appreciated thanks!!!!
I do beleive that there are a few empty slots for additional circuitry in your fuse box. See if they are hot with the ignition off or not.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 10 Old 08-30-2011, 10:08 PM Thread Starter
ewalls
yeah that was what i was originally doing i wanted to reroute some of the wires from my battery into my fuse box but then i saw the clock and radio spots that had wires coming out of them into a harness that had been cut.... confuses me because i would like to know where that originally went. Where does it go on your 95?
ewalls is offline
post #4 of 10 Old 08-31-2011, 12:04 AM
humboldtcorrado
My '93 has the same setup. Somebody used the radio spot for something to do with a trailer light harness.
'93 YJ [4L, 5sp]
humboldtcorrado is offline
post #5 of 10 Old 08-31-2011, 01:42 AM Thread Starter
ewalls
i wonder slash want to know if there was a factory spot this went to... because the harness that is cut looks factory...
ewalls is offline
post #6 of 10 Old 08-31-2011, 06:16 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
[IMG][/IMG]
post #7 of 10 Old 08-31-2011, 10:20 PM Thread Starter
ewalls
thanks for the diagram it looks like there was nothing originally in those slots. Maybe the previous owner used them for something else and then instead of removing them decided to cut the harness they were attachhed to? I dunno it would be interesting to see someone elses box of my year and model yj and see if anything came plugged in there from the factory........
ewalls is offline
post #8 of 10 Old 09-01-2011, 01:03 PM Thread Starter
ewalls
Top
ewalls is offline
post #9 of 10 Old 09-01-2011, 02:43 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
How were the wires inserted into the fuse box? Does the wiring in those spare slots look like the other factory wiring of the same color?
post #10 of 10 Old 09-01-2011, 04:01 PM
packrider
DELETE Option?
Possibly something that Jeep did as an option package. They may have offered the vehicle with no radio or clock and the dealer would up sell the option. The they made it dummy proof to add them later.
OR. The positions are controlled by the radio and clock fuse.
It's more fun to work on your Jeep than work For your jeep.
packrider is offline
1990 YJ...Fuse for Radio and Clock?????? PMW YJ Wrangler Technical Forum 11 04-29-2017 08:27 PM
Dash Clock instead of Counter RubiNoob JK Wrangler Technical Forum 18 03-09-2011 11:30 AM
Which Fuse is related to the dash gauges and radio??? gotsquat_ TJ Wrangler Technical Forum 1 12-13-2007 10:17 AM
Should be so simple - clock and radio fuse question ericw408 YJ Wrangler Technical Forum 7 07-17-2006 06:39 PM
Quick Clock/Radio Fuse/Electrical question jeepin_24 YJ Wrangler Technical Forum 1 08-30-2004 12:44 PM
