94 YJ build thread - Page 7 - JeepForum.com
post #91 of 115 Old 02-06-2013, 06:41 PM Thread Starter
stratostix
Originally Posted by AZdEvilYJ
No spring damage hopefully!?
Nope. Thankfully not.
1994 YJ
1965 Mustang Coupe Hi-po
2003 BMW 325i
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
Jeep Build thread:
stratostix is offline
post #92 of 115 Old 02-27-2013, 09:16 PM
jrhdpaintball
following your build thread...love the jeep... was hoping to see some pics of the skid you had for sale on the jeep...any chance it made it to the jeep?
jrhdpaintball is offline
post #93 of 115 Old 02-27-2013, 09:20 PM
AZdEvilYJ
Hey man, ur using the harbor freight welder right? Which one do have? I've been kinda scoping the 140 ampm
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #94 of 115 Old 02-28-2013, 12:13 PM Thread Starter
stratostix
Here's some pics of the one that's mounted to my jeep.
The skids are from barnes4wd. They have great reviews. They're basically a builder's skid. Not rdy to mount (that's why they're cheaper than all other skids out there). U have to build the transmission mounting area on them. They sell the skids for $120. I'm selling for the same price since I just got it in the mail yesterday (its brand new) but realized I ordered the wrong one. I wanted a flat/full tummy tuck skid. I'm just trying to get my money back. U could buy from them n pay the same amount... But why not help a fellow JF member and get it from me right
Anyways, like I said in the ad, ill build the mounting area on there for an extra $20. To do this, I cut a small rectangular section out of the skid where the transmission mount bolts would stick out and weld a 6" or so section of this piece of metal over the cut:
I then drill the holes in that section for the transmission mount studs to go thru. U have to do his because if u just drill thru the skid, the transmission mount studs won't stick out far enough to be able to thread the nuts on them and tighten things down bc the skid is so thick/beefy. Let me know if u have any other questions.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #95 of 115 Old 02-28-2013, 08:45 PM Thread Starter
stratostix
Skidplate is sold btw.
Anyways, here's a bunch of stuff ive done lately yo the jeep...
I mangled my front pipe on the competition course at rausch creek so i opted to go for a TJ front pipe swap. It wraps it around the oil pan up n out of harm's way
I also added to my rear bracket thingy to relocate my 3rd brake light and mount my cb antenna.
I also secured my fire extinguishers with dryer vent twist key clamps. Those r awesome
Im also preparing for a full tummy tuck. And finally i removed my steering shaft in order to replace my destroyed lower steering column bearing.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #96 of 115 Old 03-11-2013, 08:00 PM
AZdEvilYJ
What trans mount r u using w ur flat skid
'95 YJ 2.5L
My Build Thread
post #97 of 115 Old 03-11-2013, 08:36 PM Thread Starter
stratostix
I just made a cut in the skid and welded a piece of metal over it in which i drilled 2 holes for the tranny mount studs to go thru. Nothing fancy. Should work just fine.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #98 of 115 Old 03-11-2013, 10:32 PM
AZdEvilYJ
Are u running a xmember? I think without some sort bushing mount the trans will crack from engine torque... what do u think?
'95 YJ 2.5L
My Build Thread
post #99 of 115 Old 03-11-2013, 11:28 PM Thread Starter
stratostix
Im using the stock rubber transmission mount. It bolts to a "mount" i built onto the skidplate. I think we're getting confused with our definition of "tranny mount". Anyways, the tranny doesnt lay bare on the skid. It does have the rubber mount bolted to it. The skid comes raw. U have to build an area for the tranny to be bolted thru. Am i making sense?
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #100 of 115 Old 03-11-2013, 11:42 PM
AZdEvilYJ
Ahhhh gotcha! Thanks for clarifying! Looks good man
'95 YJ 2.5L
My Build Thread
post #101 of 115 Old 03-12-2013, 03:08 PM Thread Starter
stratostix
Final pic. All buttoned up. No vibes.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #102 of 115 Old 03-14-2013, 08:47 AM
jrhdpaintball
loooks great....no vibes? hows the driveline angle?
post #103 of 115 Old 03-14-2013, 09:50 AM Thread Starter
stratostix
Thx. The angle is pretty steep at the TC output but thats what the CV driveshaft is for. Except that, everything looks/feels good. My pinion angle is a cool 2 degrees below parallel. Perfect.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #104 of 115 Old 03-14-2013, 09:54 AM
fultu
I like the look of round head lights.i was thinking of using a cj grill for the conversion.
fultu is offline
post #105 of 115 Old 03-14-2013, 10:03 AM Thread Starter
stratostix
CJ grille is virtually a perfect fit.
1994 YJ
2003 BMW 325i
Jeep Build thread:
My 87' Yj Build Thread Hbeaudreau YJ Wrangler Technical Forum 77 03-18-2014 12:32 AM
New Build Thread wanabejeeper YJ Wrangler Technical Forum 70 12-17-2012 12:48 PM
My Build Thread Gobbles347 TJ Wrangler Technical Forum 6 10-17-2010 06:46 PM
95 YJ GOING BIG BUILD THREAD Here ya go!!!!! highrolrcustoms YJ Wrangler Technical Forum 34 03-26-2010 01:26 PM
YJ Build Thread??? YJ_eep1189 YJ Wrangler Technical Forum 7 12-17-2009 05:19 AM
