94 YJ build thread - Page 3 - JeepForum.com
post #31 of 115 Old 11-13-2012, 07:26 PM Thread Starter
stratostix
Those are the Chromoly 1 piece shafts i got for my HPD30. I got them (both inner and outter) and 2 dana spicer 760 u joints for a total of $280 shipped. It's about half what people pay for when they get the kit. If you wanna know where i got the deals, let me know...
Uploaded with ImageShack.us
Anyways, I'll do the 1 piece shaft conversion with those when i install my OX locker in the front. Figure might as well do it all at once.
1994 YJ
1965 Mustang Coupe Hi-po
2003 BMW 325i
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
Jeep Build thread:
stratostix is offline
post #32 of 115 Old 11-13-2012, 08:21 PM
AZdEvilYJ
Ur gonna gave to balance your front DS. The one piece makes ur ds always spin vs the 2pc completely disengages the TC til its put in 4wd. I've heard there is an mpg loss, but not 100%
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #33 of 115 Old 11-13-2012, 10:33 PM Thread Starter
stratostix
yea i realize that. There's a chance i mite get away without having to balance, but if i do have to, its no big deal.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #34 of 115 Old 11-14-2012, 05:18 AM
responder
Very nice work! You are correct in saying that metal prep is very important to making good welds.
What's next for upcoming mods to the rig?
responder is offline
post #35 of 115 Old 11-14-2012, 05:31 AM
Louie4
I really like your build and how you're going about it. Keep up the good work.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #36 of 115 Old 11-14-2012, 12:08 PM Thread Starter
stratostix
Thanks! I actually have 3 or 4 projects going on at once right now... im building a rear carrier rack (where spare tires would normally mount) to mount either a cooler, tool box or air tank. Im also going over the frame to make sure its gonna last another 20 yrs. Im saving up to get my front ox locker. Should be purchasing at the end of the month and do the 1 piece chromoly axle shaft conversion at the same time n im working on installing an engine driven OBA system. Once i get all this set up, ill be focusing on upgrading/modding the interior a little. So many projects, so little $$
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #37 of 115 Old 11-14-2012, 12:10 PM Thread Starter
stratostix
Thanks altho i couldve saved a lot of money if i knew what i wanted from thhe start... but then again thats every other jeeper's story...
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #38 of 115 Old 11-14-2012, 07:59 PM Thread Starter
stratostix
Here's how I routed my rear Ox Locker cable in case some of you are looking into getting one as well. I got the electric actuator for it. Basically, the cable comes out of the diff cover and gets routed to the electric motor. From there, all it is is wiring. You turn it on or off with the flip of a switch.
Here you can see the cable coming out of the diff on the passenger side. I bent it to route it to the driver side. It's held on loosely by a zip line at the hard brake line but at the top of the pumpkin is where i have the cable really secured.
Then the cable starts heading up towards the driver seat area.
Here u can see where i mounted the electric motor. The cable gets threaded into the motor.
And the harness goes from there.
Those 4 little bolts sticking thru the tub behind the driver oughta give you a good indication of where the motor really is mounted. I've had zero issues with this setup. The cable is not kinked. Its away from the muffler (heat) and the drivershafts (or anything else that moves). Operation is flawless.
I'll be doing the front Ox soon and will post pics of the setup as well. Hope that helps!
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #39 of 115 Old 11-15-2012, 10:27 AM
Leans93
She's my density...
Leans93's Avatar
So I saw a pic of your Jeep in that round headlight thread and I like the round light look. I was hoping you would provide some more details on that swap. It appears you did grille and hood only from the TJ correct? Also how is the hood fitment? Do you have any pictures of it close up? I know the hinges dont line up so I'm wondering how you solved that problem.
Nice looking rig!
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #40 of 115 Old 11-15-2012, 03:48 PM Thread Starter
stratostix
Nice looking rig!
Yes the hood n grille are from a TJ. The grille was raked a bit because i wanted it to have a bit of a buggy look to it. As for the hinges, i bought tj hinges and combined them with my yj hinges. Basically cut n weld to make offset hinges. The tj hood doesnt perfectly line up with the yj cowl. I ended up cutting up the tj hood to re-arch it a little bit. That is 1 part of the project that is not quite finished yet as my harbor freight welder isnt subtle enuf to weld sheet metal. So for now i bolted some plates to the hood. I dont have close up pics but ill take some for u when i get a chance. Its already very much acceptable but im a bit of a perfectionist so im eventually gonna do it right and weld the hood with the right arch. I made the fenders myself as well. Ill post more on this for u in the next couple days. Got a lot of projects im workin on right now so its just a matter of remembering.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #41 of 115 Old 11-16-2012, 05:26 PM Thread Starter
stratostix
Ok so since we're on the subject of round headlight conversions (on this thread and others), today i took off my tj hood and put my yj hood back on (still with the tj grille) to see how i like it. I actually like it very much as well so i mite tighten everything down this way for now. I can always switch back if i change my mind. If i was to do it all over again, id probably save myself the xtra work (and $$) and stick with the yj hood.
2012-11-16_16-00-57_663.jpg   2012-11-16_16-34-55_808.jpg   2012-11-16_16-01-06_78.jpg
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #42 of 115 Old 11-18-2012, 07:57 AM
Louie4
I personally like the TJ hood better. But the YJ hood looks good too. It's a win either way.
Keep up the good work!
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #43 of 115 Old 11-18-2012, 10:26 AM
AZdEvilYJ
I agree with Louie. The tj hood looks better, but it really not very noticeable. Kinda like tj flares, if u didn't own a yj u probably would never tell lol.
'95 YJ 2.5L
My Build Thread
post #44 of 115 Old 11-20-2012, 08:59 PM Thread Starter
stratostix
I havent done much work on the jeep the past few days but I did have time to get a few things done today. Mainly, i cut the hole and installed the other round LED tail light. Still havent wired them. I'm also trying to find the right size/shape metal toolbox to mount on the rear rack/carrier. The carrier itself is not finished but its getting there. Hoping to get a lot of work done this week. I also placed my order for my front OX locker yesterday. Hoping to have it installed along with the 1 piece chromoly shafts and some nice outer seals 2 weekends from now.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #45 of 115 Old 11-20-2012, 09:28 PM
AZdEvilYJ
You should make a basket which would be a bit more versatile overall. You could carry a tool box, beer cooler, or some small furniture if the situation arised. Plus you could mount the extingishers horizontally along the sides or back?? Just a thought
'95 YJ 2.5L
My Build Thread
My 87' Yj Build Thread Hbeaudreau YJ Wrangler Technical Forum 77 03-18-2014 12:32 AM
New Build Thread wanabejeeper YJ Wrangler Technical Forum 70 12-17-2012 12:48 PM
My Build Thread Gobbles347 TJ Wrangler Technical Forum 6 10-17-2010 06:46 PM
95 YJ GOING BIG BUILD THREAD Here ya go!!!!! highrolrcustoms YJ Wrangler Technical Forum 34 03-26-2010 01:26 PM
YJ Build Thread??? YJ_eep1189 YJ Wrangler Technical Forum 7 12-17-2009 05:19 AM
