94 YJ build thread - Page 2 - JeepForum.com
post #16 of 115 Old 07-28-2011, 10:37 PM Thread Starter
stratostix
At this point, i purchase 4.88 gears and an OX locker for the 8.8. Also got the electric actuator for it. This is the one job that i gave to a professional altho i see myself tackling a regear myself (with the help of a knowledgeable friend) in the future. I really want to learn. Anyways, it was time to go wheeling again.
stratostix is offline
post #17 of 115 Old 07-30-2011, 03:53 PM Thread Starter
stratostix
I also installed some A to Z fab rock sliders. U can see that in the lastest wheeling pics. That OX locker is MONEY btw. Engages/Disengages flawlessly with the push of a button. I like it so much that i'm getting one in the front as well.
post #18 of 115 Old 08-04-2011, 03:36 AM Thread Starter
stratostix
Anyways, next up was the A to Z roll cage. I used my crappy flux welder to put it together. It burns very hot but makes ugly welds unless you're welding flat. This was by far the toughest welding project i ever undertook. AFTER i was done, i realized that i couldve done a MUCH better job fitting all the tubing together which would have in turn made the welding process easier. I came out with some good welds and some pretty ****ty ones. I've left it as is for now mainly because i truly believe that it would hold up well in the event of a rollover but i'll be grinding down a fair number of those welds and re-do it.
Uploaded with ImageShack.us
post #19 of 115 Old 08-16-2011, 06:00 PM Thread Starter
stratostix
I primed the cage for now so it doesnt rust. I'll address the issues with the cage in the spring. in the mean time, I got a few things for the jeep including a PSC trail stinger, GenRight bumper plate, rear corner guards and I did a little paint and plastidip work to blend things together better.
I also swapped in an AX15 from a Cherokee with about 80k miles on it (compared to the 193K on my ax15) to freshen things up. I also have a new chain for my TC on the way. I also ordered some 1-piece chromoly shafts. i'll be cancelling the vacuum disco soon. Front OX locker will be ordered probably at the end of the month when I have the funds. I'll also be doing some frame repair by the rear shock mounts this week and overall frame maintenance. I'm also looking at making a truss for my HP30 and seeing about adding some C gussets. WJ knuckles/brakes along with a steering upgrade are in the works.... i'll try to update this stuff once I get the work done.
post #20 of 115 Old 11-05-2012, 03:30 AM Thread Starter
stratostix
Needless to say, i'm itching to go wheeling again. Unfortunately i cant go as much as I want since i have to drive 3 hrs in any direction to get to a legal wheeling spot. But i try to go as much as possible...
1994 YJ
1965 Mustang Coupe Hi-po
2003 BMW 325i
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
Jeep Build thread:
post #21 of 115 Old 11-08-2012, 08:42 PM
AZdEvilYJ
Jeeps lookin pretty sick man. I'm diggin the whole thing.
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #22 of 115 Old 11-09-2012, 12:23 AM Thread Starter
stratostix
Thanks man. Now if only i can get this damn clunky rattling issue resolved before my wheeling trip this sunday... gaaaah...
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #23 of 115 Old 11-09-2012, 12:42 AM
AZdEvilYJ
I feel Ya there. I have a coolant leak somewhere on the front of the block either pump or t-stat making my pulleys squeek, and my motor mount and exhaust mount broke so I've got all kinds of rattles. All started this week.
All my school and work leave zero down time
'95 YJ 2.5L
My Build Thread
post #24 of 115 Old 11-09-2012, 01:05 AM Thread Starter
stratostix
at least u know what it is!!
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #25 of 115 Old 11-11-2012, 04:58 PM Thread Starter
stratostix
Today I worked on fixing the frame at the passenger upper shock mount. I cleaned up the area. Cut around the rotted hole. I cut a T-section of new frame metal and started welding the new mount on there. It sure is nice welding flat again after putting the roll cage together... All of this is flux welded. Don't have a tank for now, so i'm using flux wire.
Poke around ur mounts and fix them now before they get any worse. They're veritable rust traps...
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #26 of 115 Old 11-13-2012, 12:24 AM Thread Starter
stratostix
Got it all welded onto the frame today. I'll be continuing the frame work (everything else is lookin pretty good, just want to prevent future rust) once i get my rustbullet in the mail.
The inside part.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #27 of 115 Old 11-13-2012, 08:19 AM
AZdEvilYJ
Good looking welds man.
'95 YJ 2.5L
My Build Thread
post #28 of 115 Old 11-13-2012, 01:16 PM Thread Starter
stratostix
Thanks! My attention to detail as far as metal prep has gone up. As a result, my weld quality has gone up as well. I've begun to realize that prep is 90% of the battle!
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #29 of 115 Old 11-13-2012, 05:50 PM
'92 vegas YJ
Looks great. You have a real nice looking jeep man
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #30 of 115 Old 11-13-2012, 07:14 PM Thread Starter
stratostix
Very much appreciated.
1994 YJ
2003 BMW 325i
Jeep Build thread:
My 87' Yj Build Thread Hbeaudreau YJ Wrangler Technical Forum 77 03-18-2014 01:32 AM
New Build Thread wanabejeeper YJ Wrangler Technical Forum 70 12-17-2012 01:48 PM
My Build Thread Gobbles347 TJ Wrangler Technical Forum 6 10-17-2010 07:46 PM
95 YJ GOING BIG BUILD THREAD Here ya go!!!!! highrolrcustoms YJ Wrangler Technical Forum 34 03-26-2010 02:26 PM
YJ Build Thread??? YJ_eep1189 YJ Wrangler Technical Forum 7 12-17-2009 06:19 AM
