94 Yj Bogging Down/Knocking - Page 2 - JeepForum.com
post #16 of 20 Old 08-20-2013, 10:14 AM Thread Starter
Hammons_Adam
My rear tube is almost completely broken. And both elbows are blowing oil.
Hammons_Adam is offline
post #17 of 20 Old 01-22-2014, 10:57 AM Thread Starter
Hammons_Adam
Hey guys. It been a while but here is an update. Throw out bearing failed. So I had to deal with that. Stilling having the problem. Cut out the cat and ran stright pipes. No good. Changed plugs, wires, cap, rotor. Still nothing. Changed the TPS. No luck. I'm heading out the door to go pick up a fule pressure regulator and see if that fixes things.
post #18 of 20 Old 01-22-2014, 05:39 PM
bigbossd1030
did you fix the elbows?
What about a compression test?
Fuel pressure test?
You might be throwing a bunch of parts at this for nothing.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #19 of 20 Old 01-22-2014, 06:14 PM
Que89YJ
You have probably got a bad air intake temp sensor. Check you fault codes.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #20 of 20 Old 01-23-2014, 07:46 PM Thread Starter
Hammons_Adam
Goons get the stuff and do those tests this weekend. I'll update y'all when I do
4.0 , bogging , knocking in floor pan , YJ
