94 YJ Automatic. Vibes Under load? - Page 2 - JeepForum.com
post #16 of 39 Old 10-26-2013, 06:34 AM Thread Starter
ConstantProject
Ok so I just gave up and took it to the family mechanic. Looks like it may be the transfer case or rear drive shaft. Unfortunately I'm betting its the tc because I couldn't shift it into four wheel drive. There was quite a bit if grinding. I will know by Monday so ill keep you guys posted.
ConstantProject is offline
post #17 of 39 Old 10-27-2013, 12:12 PM
jeepyj13
My buddy had a bad tcase in his old yj. Apparently the po knocked a hole in it causing drainage of ATF. I found him a used replacement online from a jeep jy. We put it in and he was off and running. He also couldn't put it in 4wd. When did the jeep will jerk like the axles had different gear ratios. That wasn't the problem it was a shot tcase.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #18 of 39 Old 10-27-2013, 01:18 PM Thread Starter
ConstantProject
I dont know if it was anything like that. I never have ha it leak any fluids until the rear diff. But i will know by monday whats wrong hopefully. If its bad im stuck with my cousins old 83 bmw. Ill tell you what i find out hopefully it can help someone else down the road.
post #19 of 39 Old 10-28-2013, 09:41 AM Thread Starter
ConstantProject
Allright heres the news. It was a bad ujoint on the rear shaft on the differential side. And the transfer case wouldnt go into 4 wheel drive because aparently there was a carcass of a possum in the way of the shifter. Which explains the smell from several months ago. I guess when i was looking i was spending most of my time checking the rear, wish i wouldve noticed a dead possum on my tcase. Hope this helps somebody. Check those ujoints.
post #20 of 39 Old 10-28-2013, 09:51 AM
sxysouthtx
Victory!!!!!!!!!!!!!!!
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #21 of 39 Old 10-28-2013, 10:38 AM Thread Starter
ConstantProject
Yep thanks for the help guys. I think the other mechanic just wanted to make a quick grand.
post #22 of 39 Old 10-28-2013, 12:08 PM
bill8bud
Good to hear. Just curious what is the cost to remove a dead possom from a jeep.
bill8bud is offline
post #23 of 39 Old 10-29-2013, 10:57 AM
pbmustache
Originally Posted by pbmustache View Post
Sounds like same thing that happened in my 93. My rear u joints were bad.
Man, I Diagnosed your problem on 10/24! When I took the U-joints out they just fell apart but when they were in the jeep they didn't look bad nor did thye have alot of play.
pbmustache is offline
post #24 of 39 Old 10-30-2013, 05:41 AM Thread Starter
ConstantProject
It was free of charge, it just required a pair of trash tongs and a few trash bags.
post #25 of 39 Old 10-30-2013, 05:44 AM Thread Starter
ConstantProject
I know you did diagnose it but wen I took the shaft loose and messed with the rear joint it was still tight, but apparently the urethane bushings were super hard and were cracking. For a minute my mechanic was even unsure about if it was bad. Thanks for the advice guys!
post #26 of 39 Old 10-30-2013, 11:51 PM
sxysouthtx
What U do we use for our D35? I've searched and can't find an answer. I plan on changing mine out this weekend.
post #27 of 39 Old 10-31-2013, 06:21 AM Thread Starter
ConstantProject
Mine was just the rear u joint on the driveshaft that goes to the rear diff.
post #28 of 39 Old 10-31-2013, 07:21 PM
sxysouthtx
I meant the part number for the u joint. My phone messed up that last message.
post #29 of 39 Old 11-01-2013, 05:23 AM Thread Starter
ConstantProject
Oh. I can try to find it but it may not be correct as there is an aftermarket rear shaft in it.
post #30 of 39 Old 11-01-2013, 06:17 AM
EABiker
You have just proven when diagnosing a Jeep problem, make sure you check out all the possumbilities!
EABiker is offline
differential , drive line vibration , rear axle , vibration on acceleration
