94 YJ 4wd doesn't' work. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94 YJ 4wd doesn't' work.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 07-06-2013, 03:05 PM   #1
txwrangler94
Hi, Guys I have a 94 YJ and my 4WD isn't working. I looked at the actuator and my switch for it has been frayed. (see pic) I was wondering where to get that switch? Alot of people talk about the switch on the transfer case but this one is on the axle. Also would this switch cause my 4WD not to engage?
txwrangler94 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2013, 03:21 PM   #2
Jeepsr4me
That switch only turns the light on the dash.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 07-06-2013, 06:12 PM   #3
Michaelgoesrawr
Michaelgoesrawr's Avatar
This. How do you know your 4x4 doesn't work?
Michaelgoesrawr is offline   Reply With Quote Quick reply to this message
Unread 07-06-2013, 10:19 PM   #4
bigbossd1030
Agreed, just because the light doesn't come on, doesn't mean it's not in 4wd. Take it either to a parking lot and do a tight turn when in 4wd. If it lurches around, it's in 4wd. Or gravel road and do a burnout to see if they all are spinning. Or jack up front and back and see if they all spin.
Sent from my iPhone, probably because I am bored at work.
[COLOR="DarkGreen"]/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)[/COLOR]
[COLOR="Blue"]OFFICIAL JEEPER[/COLOR]
[COLOR="Red"]Any Jeepers in Edmonton, AB
I am on channel 33.[/COLOR]
I live, I ride, I am JEEP.
bigbossd1030 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 07:12 AM   #5
Jeepsr4me
Originally Posted by bigbossd1030 View Post
Take it either to a parking lot and do a tight turn when in 4wd. .
Never do that^^^^^
. You will destroy the transfer case.
Dirt road or grass or gravel or ice and snow are the only good places to test 4x4..
Unread 07-07-2013, 10:44 AM   #6
Anticanman
RIP one good jeeper
Anticanman's Avatar
Jack stands are a much better route. They're cheap and allow to see what is turning instead of what is rolling.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 10:45 AM   #7
bigbossd1030
Never do that^^^^^
I know it says not to engage it on dry pavement, but I have read this test in the faqs section when I first started reading jeep forum. It hasn't caused me any problems. Maybe I should have specified, do this at an extremely slow speed. That's what I do, I knew it was in 4wd in less than 180 degrees of turn. I don't know, it may be wrong, but my t case is still going strong and the only work I have ever done on it was the rear output shaft seal. Has no one else down this to test it?
l----L-[]lllllll[]-
Unread 07-07-2013, 10:53 AM   #8
bigbossd1030
Sorry it wasn't the FAQ section but it was in a post in 2006. All the ways I said are mentioned here and no one said it would be a problem if you take it slow.
http://www.jeepforum.com/forum/f12/h...-drive-298581/
Sorry if I caused any confusion to matter it was a late post for me lol.
l----L-[]lllllll[]-
Unread 07-07-2013, 11:10 AM   #9
Jeepsr4me
Just wise to never do it. The forces involved will bend and break stuff.
Unread 07-07-2013, 11:54 AM   #10
bigbossd1030
This is a possibility, you're right. Suppose the safest and easiest way would be a gravel road.
l----L-[]lllllll[]-
Unread 07-07-2013, 12:41 PM   #11
Anticanman
RIP one good jeeper
Anticanman's Avatar
Jackstands.
Unread 07-07-2013, 01:12 PM   #12
dancytron
Assuming transfer case is working, you just need to jack up one wheel to check it. http://www.jeepforum.com/forum/f12/h...-hubs-1308217/
dancytron is online now   Reply With Quote Quick reply to this message
Unread 07-09-2013, 05:39 PM   #13
txwrangler94
I know it doesn't work because I got stuck in the sand when I had it in 4WD and the front didn't engage.. So could it be my solenoid on the transfer case is bad as well? And lets say I fix this 4WD light switch will it only light up is power to the axle is applied or just when the vacuum solenoid engauges?
Unread 07-09-2013, 05:53 PM   #14
Michaelgoesrawr
Just when the vacuum activates your cad. The thing sticking out on the passenger side. So you have a vacuum problem somewhere.
Unread 07-09-2013, 07:32 PM   #15
Siva283
Jackstands.
This. Its the best easiest and also the easiest on the driveline. What bigboss was telling you binds the drive line that's why it lurches. Somerhings gotta give and doing it thay way you betrer hope its the tires and not thw tcase or an axle shaft
Sent from my SPH-L300 using JeepForum
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
