94 XJ 4.0HO into a 94 YJ 2.5 Questions - JeepForum.com
post #1 of 11 Old 03-25-2014, 02:28 PM Thread Starter
big_green_94YJ
I have a complete drivetrain from a donor 1994 cherokee, 4.0/ax15/np231, engine harness, fuse box, and computer. I plan on dropping it in my 94 yj that currently has a 2.5/ax5/231. I've done some extensive searching, but my results have been scattered. I know about moving the frame mounts, and clocking the transfer case. Mostly I'm concerned about the wiring, not sure if I should use the XJ harness, or splice in the two extra injector wires and plug the XJ computer in and be good to go. Just looking to smooth out wrinkles before i begin the tear down. Any help would be appreciated.
big_green_94YJ is offline
post #2 of 11 Old 03-25-2014, 02:29 PM
jsawduste
2006 YJ Wrangler
splice in the 2 injector wires and be done.
jsawduste is offline
post #3 of 11 Old 03-25-2014, 02:39 PM Thread Starter
big_green_94YJ
great, thanks for the quick response!
post #4 of 11 Old 03-26-2014, 03:29 PM
imstillatwork
Wiring is so easy.
Take a few donor wires from the Cherokee ECM plug and add them to the YJ. Much easier than swapping harnesses.
Overall transfer case will end up about 2 1/2 inches further back then the 2.5, so make sure you double check that it won't be compressed too much.
imstillatwork is offline
post #5 of 11 Old 04-08-2014, 02:17 PM Thread Starter
big_green_94YJ
I have an sye and a driveshaft for the tcase, so that doesn't really seem like a big issue to me. some say fuel pressure will be an issue, others don't even mention it at all. Like I said before, just trying to get all of my ducks in a row before I pull everything apart, as my jeep is my DD. Hoping this will end up being a solid reference thread for people doing similar swaps.
post #6 of 11 Old 04-09-2014, 05:54 AM
StanF
I used an engine from a 98 TJ for my 2.5L swap, and I had to change out the fuel rail. I'm not familiar with the XJ fuel rail, but you'll want to use a fuel rail with the pressure regulator on the rail (it'll look just like your 2.5L fuel rail, but longer). It'll have a gas inlet and return line on the rail. And you'll want to get injectors to match. If this isn't clear or if you need pictures, just let me know.
StanF is offline
post #7 of 11 Old 04-09-2014, 06:40 AM
Que89YJ
Fuel pressure is not an issue if you are going from the throttle body injection.
Que89YJ is offline
post #8 of 11 Old 04-09-2014, 12:59 PM
StanF
To clarify my earlier post...
Fuel pressure regulation might be an issue...didn't the XJ have regulation in the tank like a TJ? If so, the fuel rail swap is the easiest solution.
You'll also want to make sure the injectors match your fuel pressure regulator
StanF is offline
post #9 of 11 Old 04-09-2014, 01:22 PM
Que89YJ
For the obd2 yes it did. Anything 96 & beyond.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #10 of 11 Old 04-09-2014, 02:17 PM
Varnish
Varnish's Avatar
A few different options if it isn't regulated at the rail. On my CJ swap I ran an external pump (but would work with internal as well, combined with a WJ fuel filter which has a regulator built in and then run return line to stock return line.
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #11 of 11 Old 04-09-2014, 03:22 PM
StanF
I might be thinking of ZJ - I think they had the regulator in the tank for some of the OBD1 years
StanF is offline
