94 wrangler:rough idle, now no spark - JeepForum.com
post #1 of 3 Old 04-19-2010, 03:46 PM Thread Starter
mattice
I have a 94 yj 4 cylinder and in the begining of my problems it was having a rough idle and I would have to give it gas until it warmed up but after it warmed up it would cut off and then would not start back up right away. The codes that it put out were: 12, 33, 23, 24. I have replaced or checked the following: o2 sensor, fuel pressure regulator, map sesnor, mat sensor, throttle position sensor. Not sure what to check out next, thinking the crankshaft sensor or the ecm. Thanks for the help.
mattice is offline
post #2 of 3 Old 04-19-2010, 04:22 PM
Que89YJ
First the basic no start question: Does the fuel pump cycle on and then off when you turn the ignition key to on? When you say you checked, what did you replace and what did you check and how? Do a battery disconnect for a minute(10 seconds is usually long enough but just to make sure) and then try to start it again. Recheck the fault codes. If you had a rough idle but it ran fine after it warmed up it is usually 1 of 2 sensors; the TPS or the engine temp sensor in the front of the block near the thermostat.
Que89YJ is offline
post #3 of 3 Old 04-19-2010, 04:51 PM
idaholtby
Originally Posted by mattice View Post
I have a 94 yj 4 cylinder and in the beginning of my problems it was having a rough idle and I would have to give it gas until it warmed up but after it warmed up it would cut off and then would not start back up right away. The codes that it put out were: 12, 33, 23, 24. I have replaced or checked the following: o2 sensor, fuel pressure regulator, map sensor, mat sensor, throttle position sensor. Not sure what to check out next, thinking the crankshaft sensor or the ecm. Thanks for the help.
With a 23, and 24 code stored.... this would suggest that your CTS(coolant temp sensor for the ecm) sensor is bad. It is located on the thermostat housing. Your ecm is flagging this sensor, so I would start from there.
idaholtby is offline
no spark , rough idle
1995 Jeep Wrangler runs rough won't idle serge110 YJ Wrangler Technical Forum 20 01-28-2011 05:22 AM
1997 Wrangler Rough Idle when cold...please help, newbie in distress seanace1 TJ Wrangler Technical Forum 10 08-10-2009 12:52 PM
Changed Spark Plugs Rough Idle djfred YJ Wrangler Technical Forum 20 12-10-2008 09:19 PM
1995 Wrangler has rough idle Huskers9855 YJ Wrangler Technical Forum 3 01-23-2008 06:04 AM
Changed the spark plugs yesterday, now the idle feels a little rough. JeeperCane YJ Wrangler Technical Forum 30 09-26-2007 04:48 PM
