94 wrangler ignition problems - JeepForum.com
post #1 of 3 Old 05-16-2010, 03:55 PM Thread Starter
st2joker
I have a 94 wrangler 4.0. it seems to start fine, but once its warmed up if i let it idle it dies, i replaced the cap rotor and pick up coil, but its still doing it,while im driving it it acts like i turned the key off for 3 or 4 seconds and then it continues to run, ive ran it with a fuel pressure gauge on it and it doesnt seem to be a fuel problem which is why i changed the pick up cap and rotor. has anyone else had this problem or do you have an opinion on what i should check next.
st2joker is offline
post #2 of 3 Old 05-16-2010, 04:16 PM
MDonovan8
It could be one of two things. IAC (Idle Air Control) or the TPS (thottle position Senor). After that I would check the vacuum lines.
Freedom is not free, THANK YOU all service men and women.
MDonovan8 is offline
post #3 of 3 Old 05-16-2010, 08:32 PM
Que89YJ
Look in the Faq on checking fault codes. I think you have a bad O2 sensor. Diagnostic Trouble Codes
Que89YJ is offline
yj ignition problems. help 89yjwheeler YJ Wrangler Technical Forum 9 01-18-2010 03:19 PM
2001 Wrangler Ignition Problems. Need Help CPClink5955 TJ Wrangler Technical Forum 3 09-14-2008 08:52 AM
Ignition Problems with 97 TJ Wrangler ted1888 TJ Wrangler Technical Forum 6 01-24-2008 06:23 PM
Ignition Problems ??? timatoe YJ Wrangler Technical Forum 2 09-01-2007 08:39 AM
ignition problems lovemy'79350 YJ Wrangler Technical Forum 9 07-14-2005 07:24 PM
