94 wrangler host 2.4/93 cherokee donor 2.4 -ecm questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94 wrangler host 2.4/93 cherokee donor 2.4 -ecm questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIron Rock Offroad products - get them from Kolak!TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/
Unread 03-31-2015, 07:41 PM   #1
jeepjeff14
94 wrangler host 2.5/93 cherokee donor 2.5 -ecm questions
I have a 94 wrangler which had a blown motor. I put a motor from 93 cherokee in ( both are 2.5) . All went well until I tried to crank it and got nothing. Got new battery and new starter. Still nothing when I turn key on. I do have lights with key but I also don't hear fuel pump. So I started thinking about the harness ecm and there are several things different. I had my husband helping me but he's out of town currently and thought it would be nice to have it running when he got home. I don't want to sound stupid but could these pin outs be the problem?
jeepjeff14 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2015, 08:05 PM   #2
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
Originally Posted by jeepjeff14 View Post
I have a 94 wrangler which had a blown motor. I put a motor from 93 cherokee in ( both are 2.4) . All went well until I tried to crank it and got nothing. Got new battery and new starter. Still nothing when I turn key on. I do have lights with key but I also don't hear fuel pump. So I started thinking about the harness ecm and there are several things different. I had my husband helping me but he's out of town currently and thought it would be nice to have it running when he got home. I don't want to sound stupid but could these pin outs be the problem?
Check your ground strap
ashland82391 is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 05:13 AM   #3
Que89YJ
You are an awesome wife! First they are 2.5L. The ecu's are the same. Unless you swapped the harness it doesn't matter. Real easy to figure out. Does the check engine light come on and go off when you turn the key on? Its important because the light will tell you the ecu is getting correct power.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 02:01 PM   #4
Jeepsr4me
Why did you not keep the wrangler harness?
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 05:58 PM   #5
Que89YJ
I think she did. I think the cel.isn't coming on because the fuse blew.
Unread 04-02-2015, 03:43 PM   #6
jeepjeff14
Sorry about the typo (2.4) my daughter posted for me. Thanks for responding. I was gave the wiring harness and ecu with motor from cherokee, I did not change harness out just motor,trans,new starter,alternator, battery. And someone had knocked ignition out so we replaced that also. When I turned ign on this morning I didn't get check engine light only up shift lights comes on and stays on and seat belt light stays on about 4 sseconds also have headlights,blinkers,brake lights but no back running lights. Nothing else happens when I turn key to start. I am going down this evening to check all grounds. Could you tell me which ones I should have ? I did put other ecu in and check engine light came on without key being on so I removed it and put original back in. I checked fuses they were OK ( I did that day before yesterday).I appreciate any help you can give me to try to remedy this and get this thing running, I really want to get it going to surprise him . I bought this for him after he rolled his cj-7 on thanksgiving. But it has not run yet lol...
Unread 04-02-2015, 07:10 PM   #7
Que89YJ
Do have and know how to use a meter?
Unread 04-02-2015, 07:12 PM   #8
Que89YJ
You have a power issue. The cel not coming on its easy to diagnose. I will link you a thread to trouble shoot it if you do.
Unread 04-02-2015, 08:54 PM   #9
jeepjeff14
Yes I do have one...ugh...and yes I do know how to use it ( the ugh was because I don't particularly care for electrical work but I do have a friend whom I could get to double check my work lol) thanks again for the help. This has been going on for too long now
Unread 04-02-2015, 09:01 PM   #10
Que89YJ
Ok read through this
http://www.jeepforum.com/forum/f12/9...orumsite/20623
The power checks will tell us where to look.
Unread 04-02-2015, 09:08 PM   #11
jeepjeff14
I was just wondering if it could be one of those pin outs on ecu? Just asking because one of the ones that were different was a battery ( I believe no 3..
Unread 04-02-2015, 09:29 PM   #12
Que89YJ
no. The ecu is the same. Follow the instructions and I will be you don't have power on pin 9
Unread 04-10-2015, 07:43 PM   #13
jeepjeff14
Sorry been real busy but your right no power to num 9....
Unread 04-11-2015, 05:57 AM   #14
Que89YJ
You need to check for a missing or blown fuse in the fuse panel at the drivers feet. Dome fuse our ign lps. Yes the dome fuse.
