94' Wrangler engine problem - JeepForum.com
post #1 of 5 Old 09-30-2010, 08:18 PM Thread Starter
crash183
My brother just bought a 94' Wrangler with a 2.5L 4 cylinder and it's missing between about 2000 and 3000 RPM. Does anyone have any suggestions? He's replaced the O2 sensor and the crank positioning sensor, checked the plugs and wires and everything else we can think of. Any ideas?
crash183 is offline
post #2 of 5 Old 10-01-2010, 06:15 AM
Roadyy
Take the TPS and the AIC off of Throttle body and clean them. They are the 2 sensors connected to the throttle body. May also check the Temp Sending Unit at the thermostat housing to make sure it is good. If temp unit is bad it will not allow the ECM to get out of closed loop.
Roadyy is offline
post #3 of 5 Old 10-01-2010, 12:48 PM
squirrley
I would start with the TPS and AIC like UBAY194 said then i would move onto the fuel system.Could be a "lazy" fuel pump
squirrley is offline
post #4 of 5 Old 10-01-2010, 11:30 PM Thread Starter
crash183
Re:
Hey guys, thanks, I'll let him know and I'll reply with the results.
crash183 is offline
post #5 of 5 Old 10-02-2010, 04:05 AM
Mark05059
I would also do a complete tune up (cap rotor plugs wires) on it as well.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
2.5 liter , engine , missing , wrangler
2.4L '03 Wrangler Engine Oil? -C- TJ Wrangler Technical Forum 4 04-26-2015 09:14 PM
1984 CJ7 6 cyl 258 engine swap into 1988 wrangler with 6cyl 258 engine? xavier27 YJ Wrangler Technical Forum 0 07-29-2010 02:08 PM
89 Wrangler engine help glcoxe YJ Wrangler Technical Forum 5 06-26-2010 06:29 AM
wrangler engine help johnt7558 YJ Wrangler Technical Forum 3 10-20-2009 08:04 AM
Engine problem not getting fuel or engine missing help please!! johngendron YJ Wrangler Technical Forum 0 08-22-2009 06:49 PM
