94 wrangler clutch pedal loosing pressure - JeepForum.com
post #1 of 5 Old 07-27-2013, 01:55 PM Thread Starter
Tony01
Hi all
my clutch pedal sometimes goes to the floor without disengaging the clutch, it seems to loose pressure but only now and then, most of the time it is ok.
My jeep is a 94 wrangler so it has a slave and a master cylinder, there are no leaks at the slave, master or under the clutch pedal linkage. can the system be bled as I cannot find a bleed screw on it. Or is it a case of fit a new one, I live in the U.K and the main dealers dont stock them so it will have to be an ebay job. Any help in the matter would be most welcome,
many thanks Tony.
Tony01 is offline
post #2 of 5 Old 07-27-2013, 02:21 PM
kahanabob
time for a new master cylinder...............
kahanabob is offline
post #3 of 5 Old 07-27-2013, 03:28 PM
caoboy
Try rockauto.com before you go to eBay!
caoboy is offline
post #4 of 5 Old 07-27-2013, 04:05 PM
pasinbuy
The bleeder is on the slave and I believe it is a allan head.
pasinbuy is offline
post #5 of 5 Old 07-28-2013, 05:27 PM Thread Starter
Tony01
thanks for the replys I will bleed it at the weekend, weather permitting.
Tony01 is offline
