94 voltage regulator - JeepForum.com
post #1 of 7 Old 01-13-2011, 05:16 AM Thread Starter
lxndrmdean
Im new to the forum and im still learning as i go. sorry if I sound like an idiot from time to time, i can fix an A-10 better than i can fix a car. anyways.. my YJ's electrical went out while driving home one day starting with the guages and then eventually dying all together. since then ive replaced the alternator and tried to jump it but no luck. Like i said before i know very little and all i can think of is replacing the battery cables or the voltage regulator. however this voltage regulator eludes me and i cannot find any text on the matter. any help would be amazing, thanks guys!
lxndrmdean is offline
post #2 of 7 Old 01-13-2011, 05:26 AM
Old4X
1990 CJ7
The voltage regulator circuitry is in the ECM, behind your glove box. (part of the computer, not separate)
Have you checked your Maxi-fuses under the hood?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 7 Old 01-13-2011, 05:33 AM
Que89YJ
Not behind the glovebox in his, its under the hood. X2 on everything else. Check the maxi fuses under the hood and check for a blown fuse by the drivers feet fuse panel for the cluster.
Que89YJ is offline
post #4 of 7 Old 01-13-2011, 06:23 AM Thread Starter
lxndrmdean
like i said, still figuring this thing out, but no i haven't checked the Maxi-fuses that'll be my first stop once the sun rises
post #5 of 7 Old 01-13-2011, 07:07 AM
MDonovan8
The maxi fuse are the first place to look. Had this happen last summer to my 94' YJ. It will be a red colored fuse that I believe is a 50.
Freedom is not free, THANK YOU all service men and women.
MDonovan8 is offline
post #6 of 7 Old 01-13-2011, 07:56 AM Thread Starter
lxndrmdean
Ok, its not the maxi's under the hood, none of those were burned up. i can hear the ignition ticking, and an occasional turn or two but no luck after that even while jumping, which is why im led to believe its the battery cables. other than the alternator maxi fuses under the hood, is there any other obstacle that would keep me from starting the beast?
post #7 of 7 Old 01-13-2011, 08:52 AM Thread Starter
lxndrmdean
Got It! thank you all kindly! it was the a bad connection on the lower end of the positive battery cable.
alternator replacement , stalling , voltage regulator
voltage regulator bgreen TJ Wrangler Technical Forum 20 07-01-2013 08:29 AM
voltage regulator yj35s YJ Wrangler Technical Forum 4 08-01-2009 02:04 AM
Voltage Regulator or something else? ducrider YJ Wrangler Technical Forum 14 05-06-2007 08:36 PM
voltage regulator Jeepdrivinmid TJ Wrangler Technical Forum 4 05-06-2006 11:01 AM
voltage regulator ?? NJJeeper YJ Wrangler Technical Forum 3 01-19-2003 11:51 AM
