Quantcast 94" should i Axel swap and Leaf over axel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94" should i Axel swap and Leaf over axel
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 12-20-2008, 06:05 PM   #1
Keiser
Hello, i have a yj (obviously) that i use as a daily driver
(20 miles/day 90% gravel) i have stock everything, should i put new axels under it? If so what axels should i use? What is my cheapest way to lift it to fit 33s? Is a leaf spring over axel lift advisable?
Thanks,
Jordan
ps: sorry if this is a repeated question i just didnt know where to look.
Keiser is offline   Reply With Quote
Old 12-20-2008, 08:20 PM   #2
jeepin1995
jeepin1995's Avatar
Thanks,
Jordan
i wouldn't advise an SOA lift unless you have read up extensively on it.....there's a search function up top of this page, there are days worth of reading on SOA there.....
if you just wanna run 33's, i'd go with prob a 3" lift and maybe some TJ flares....
for axles..... the front axle is fine for 33's, the rear is debatable (there have been posts with hundreds of replies on this). if you wheel HARD i'd look into a d-44 or 8.8......
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
WWW.FLATLANDROCKCRAWLERS.COM
350 in my YJ.....
http://www.jeepforum.com/forum/f12/my-350-swap-518364/
build thread:
http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/
jeepin1995 is offline   Reply With Quote
Old 12-20-2008, 10:28 PM   #3
Keiser
thanks, i will look into it
Glock Forum
