'94 radio wiring - JeepForum.com
post #1 of 8 Old 03-12-2012, 08:09 PM Thread Starter
jbbaker
'94 radio wiring
I have a '94 YJ and for the past year my radio has been working off and on. It goes through spells where it will work perfectly and at times it will just flicker on and off for roughly 2 second increments.
I wasn't sure if it was the radio (an old pioneer) so I bought a new one today. After changing the harnesses and plugging in the new radio the same problem continued. I checked the 3 main wires, battery (yellow), acc (red), and ground wires. I used a light circuit tester to check the battery/acc wires and it held a steady glow. The radio is plugged straight into the "clock" fuse in my fuse box. The fuse in the back of the radio is good too. I've even redone the wiring connections and the ground. I'm out of ideas...
Please anything would help. I hope I gave enough information. My KC Daylighters have also stopped working. I wouldn't think them to be related problems though, since they are different parts of the electrical system.
Thanks in advance.
JB
jbbaker is offline
post #2 of 8 Old 03-14-2012, 12:13 AM
JeepJourney1624
I'm having the same exact problem. Although the radio i have is a newer model. I think maybe its time to take it to an electrical expert.
JeepJourney1624 is offline
post #3 of 8 Old 03-14-2012, 02:02 AM
sprngrider
Is the faceplate detachable? If it is, those pins can also get dirty and cause problems.
1994 2.5L WRANGLER S.
sprngrider is offline
post #4 of 8 Old 03-14-2012, 02:05 AM
benmar2000
I would run a wire directly from the battery to test it.. This will let you know if it is the radio or another issue in your electrical wiring..
benmar2000 is offline
post #5 of 8 Old 03-14-2012, 08:40 PM Thread Starter
jbbaker
Thanks for the responses. I tried a brand new radio and the same problem occurred so I don't think it's the pins on the face plate. I improved some of the wire connections and managed to get steady power to the radio, however; it now shorts out at a certain volume. Could it not be receiving enough power? I only have 2 6x9 and 2 6 1/2" speakers.
If I don't get it fixed by the end of the week I may have to give up and take it to someone.
jbbaker is offline
post #6 of 8 Old 03-14-2012, 09:00 PM
predat
Did you do a quick run over on all the connectors leading to the speakers? Might be a loose solder on the speakers themselves, perhaps at a certain volume, the connection is lost or is crossing, causing the short. I'd also check the specs on the stereo, see if the amperage is distributed correctly, do you have an amp? If so, check it's capability and connections. If not, then have you considered the possibility that you might not have enough amperage from your stereo itself?
Just some thoughts I had running through my head about past experiences I've had with electronics in general.
predat is offline
post #7 of 8 Old 03-14-2012, 09:14 PM
benmar2000
Sounds like it might be an impedance issue. You might be running 2 ohm speakers on a 4 ohm output.. I had that issue on an amp when I hooked up my sub.. I thought I had switched it to 2 ohms but it was on 4 ohms.. When I would turn up the volume past a certain level, the amp would shut down.. Once I switched it to 2 ohms, it fixed this issue.. Just an idea..
post #8 of 8 Old 03-14-2012, 10:27 PM
jfinlaw
I actually have the EXACT problem in my '94, with an old pioneer deck. Just today I took it to a local car audio shop... Guy says $200 bucks will get my speakers replaced, he'll fix the wiring issues, and another 100 will get me a new deck...
Green Jeep Club #633
You had me at bacon wrapped. :drool:
jfinlaw is offline
electrical issue , electrical problem , power , radio
Radio Wiring? qlfarm YJ Wrangler Technical Forum 4 01-06-2012 04:26 PM
Radio wiring bigunn YJ Wrangler Technical Forum 2 12-24-2011 02:01 PM
Wiring for an CB radio Sailorny JK Wrangler Technical Forum 14 05-04-2007 06:55 PM
Is Radio wiring present if jeep originally came without a radio gary1 YJ Wrangler Technical Forum 14 02-07-2006 09:10 PM
92 YJ Radio wiring Shinner YJ Wrangler Technical Forum 0 09-23-2003 05:37 PM
