94 engine troubles. Hope this helps someone else - JeepForum.com
post #1 of 1 Old 04-23-2010, 05:06 AM Thread Starter
Muaymendez
Well it started when I bought the jeep. HAd nasty fuel in the tank which I drained and replaced with fresh fuel. RUnning better imeadiatly. I took her out for a spin , and took me about 80 miles on easter sunday.
Went light crawling and mudding with a cuople of buds.
On the way home she started spitting and sputtering keeping me at 60 on the highway. Then 50, 40 30, and to the point where I had to jump off th highway and limp home.
It was so bad that anytime I would start her up and drive around the block I would have trouble getting her home.
WELL folks it was the fuel pump.
The strainer had so much crap that it made the pump run dry a few times causing me to sputter.
If I would turn the key in off position and turn it on 2 times to PRIME the engine it would run a gain for a short while.
Pictures soon.
Muaymendez is offline
Engine Troubles....Again clemsonfan16 YJ Wrangler Technical Forum 15 02-23-2010 05:45 PM
Engine troubles!!! Eriksm YJ Wrangler Technical Forum 7 02-22-2010 11:26 AM
I hope this engine comes forth!!! medicbear JK Wrangler Technical Forum 6 03-12-2009 12:13 PM
engine troubles JJ-4 YJ Wrangler Technical Forum 2 03-20-2008 09:44 PM
Engine Troubles!!! bonz504 YJ Wrangler Technical Forum 2 02-20-2003 10:52 PM
