94 Bronco 8.8 - JeepForum.com
post #1 of 12 Old 01-22-2013, 08:26 PM Thread Starter
Taylor_44
94 Bronco 8.8
Found an 8.8 out of a 94 ford bronco for $200. Would this still be a good axle for a 91 YJ? I see most people recommend the Ford Explorer 8.8, I there a difference?
Taylor_44 is offline
post #2 of 12 Old 01-22-2013, 08:29 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Not good for YJs.
Yes, they're different. Width/wheel bolt pattern/drum brakes are the major differences.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 12 Old 01-22-2013, 09:15 PM Thread Starter
Taylor_44
Thanks, I'll stay away from them then.
post #4 of 12 Old 01-22-2013, 10:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Stick to explorers. They're everything you're going to need. The full width doesn't have the strength that the exploder does.
Luck Favours The Prepared
Anticanman is offline
post #5 of 12 Old 01-22-2013, 10:59 PM Thread Starter
Taylor_44
If I replace the rear with an 8.8 and stick with the D35 in front, what would be the max tire size to run with out busting axles excessively?
post #6 of 12 Old 01-22-2013, 11:37 PM
zte87
GIVE IT THE ONION
zte87's Avatar
You have a dana 30 up front but any ways most people say that combo is good up to 35s!
zte87 is offline
post #7 of 12 Old 01-22-2013, 11:50 PM Thread Starter
Taylor_44
So if the D35 and the 8.8 are both good up too 35's, what's the incentive to pay the money and upgrade to the 8.8?
post #8 of 12 Old 01-22-2013, 11:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Slow down. The stock axles under your jeep are a Dana 30 front which is good to 35's when you feed it a wheelbarrow of moneybags and a Dana 35 out back which is a ticking time bomb even on 31's.
That's my jeep. Broke it in 2wd on the street. Mhmm
post #9 of 12 Old 01-22-2013, 11:58 PM
zte87
GIVE IT THE ONION
zte87's Avatar
I meant the dana 30/ 8.8 combo was good up till 35s........I would't want to run a stock dana 35 with even 31s but that's just me! Even after people throw money at the 35 it's still a turd, I bought my jeep with a super 35 kit installed in it and I still messed it up running it with only 33s (my axle tube started to twist) which is why I am now running a 8.8 out back!
zte87 is offline
post #10 of 12 Old 01-23-2013, 12:02 AM Thread Starter
Taylor_44
I don't plan on anything higher than 35's... As of right now, I'm sure that will change! I'm on a budget, but trying to do the most for my money. 8.8 looks to be the most cost effective.
post #11 of 12 Old 01-23-2013, 12:04 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The 8.8 is the most cost effective and its good to 37's or much higher if you have chromoly shafts and a truss.
post #12 of 12 Old 01-23-2013, 06:44 AM Thread Starter
Taylor_44
Thank you for the help and info.
