94 and 95 wrangler - JeepForum.com
post #1 of 4 Old 02-20-2012, 06:18 PM Thread Starter
brutus1114
94 and 95 wrangler
I have a 1995 jeep wrangler will the transmission from a 1994 6 cyl work on my 95 it is a 4 cyl. Both are 5 speed manual.
brutus1114 is offline
post #2 of 4 Old 02-20-2012, 06:24 PM
dillonjm
2013 WK
Its not the same transmission and will require more work to swap it in but it can be done.
It is an upgrade though, but you'll need to swap t-cases as well among some other stuff. Look up AX-15 swap for 2.5L or something along those lines, should be some info out there.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 4 Old 02-20-2012, 06:27 PM
gunshw301
Advance adapters sells a conversion plate to mate up the ax15 to the 2.5l. It's on my list.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #4 of 4 Old 02-20-2012, 10:25 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
Take some time and do some more research.
site:jeepforum.com/forum/f12 ax15
Back Road Jeepin
BackRoadJPin is offline
Will hardtop and doors from 1990 Wrangler fit on 1992 Wrangler? jacksprat1 YJ Wrangler Technical Forum 5 09-23-2010 08:22 PM
Trade 05' Wrangler X and $1000 for 05' Wrangler Unlimited? GMBNT42 TJ Wrangler Technical Forum 28 03-13-2009 08:48 AM
Turn a 1997 Wrangler into a 2006 Wrangler MeSoDumm TJ Wrangler Technical Forum 14 06-25-2008 09:24 PM
Will a 1989 Wrangler Full steel door/hard top fit on a 1995 Wrangler alandchris YJ Wrangler Technical Forum 2 03-13-2007 03:51 PM
Using a Soft-Top From a 2000 Wrangler on a 1998 Wrangler? Nighthawk TJ Wrangler Technical Forum 3 06-05-2002 05:02 PM
