Quantcast 94 2.5 still having problems HELP - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 94 2.5 still having problems HELP
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 03-02-2009, 01:39 PM   #1
lckdrgn
lckdrgn's Avatar
Thought we were making progress, not much worse. I have replaced:
o2 sensor
temp sensor
fuel filter
It was getting to 3500 RPM still not accelerating much. When at 2500 floor the throttle and almost nothing happens, Now coming home last night fom work it will not go past 3000rpm starts to die. if I down shift has to above 3000 it sounds like it stalling, have to get out of the gas to get below 3000. Third gear2500 small grade floor it, nothing.
Some one said change the TPS and replace vac lines, I guess thats next I sure take any ideas. I not a mechcanic, not a bad parts changer. I almost up to taking to a stealer to get checked out, will have to wait till i can fund the dealer.
Any more help would be appreciated. It's parked for now.
Thanks
Luck Dragon
Kelly
lckdrgn is offline   Reply With Quote
Old 03-02-2009, 03:35 PM   #2
SECorBust
I may not be able to help at all and only confuse you, but I had a problem with my 2.5 that I couldn't figure out. The power wire to the coil had gotten to where it would ground out through the insulation causing the jeep to not run. I think heat from the engine had broked down the insulative properties of the wire. Make sure that your rig is getting the propper amount of spark.
My jeep also acts the way you described when it is out of gas. It never hurts to check.
SECorBust is offline   Reply With Quote
Old 03-02-2009, 04:04 PM   #3
94YJEEPER
Im having the same problems... when ever I give it some gas, it acts like its out of gas and wants to stall... Do you get a check engine light?
1994 Jeep Wrangler 2.5l.
2in lift
TJ wheels and 32in BFG AT's
Warn M8000 winch
94YJEEPER is offline   Reply With Quote
Old 03-02-2009, 04:18 PM   #4
Ironworker709
Ole Ironhead
Ironworker709's Avatar
try the cat converter
Ironworker709 is offline   Reply With Quote
Old 03-02-2009, 04:28 PM   #5
TheRealOldjeep
Could also be the crank position sensor. Mine came loose once and it wouldn't rev high, would stumble.
Are you getting a check engine light and any codes?
Chuck P
94 YJ 2.5L/AW4
http://www.jeepforum.com/forum/f22/94-yj-649943/ Build Thread
www.oldjeep.com My site
www.mntrailriders.org My Club
TheRealOldjeep is offline   Reply With Quote
Old 03-02-2009, 06:26 PM   #6
lckdrgn
lckdrgn's Avatar
no check engine light. Just will not run at all above 3k rpm.
Old 03-02-2009, 07:56 PM   #7
StormlessWolf
Id check the cat and spark plugs. This is a maybe, but it could be bad ignition coil and distributor cap (If any of this is wrong, please correct me).My cat just went last week. If it is the cat, go for an Direct fit, those universals restrict the crap out of your engine! Any bad rattles in the area around the converter or weird smell of sulfur?
"All that we are is the result of what we have thought. If a man speaks or acts with an evil thought, pain follows him. If a man speaks or acts with a pure thought, happiness follows him, like a shadow that never leaves him."
- Buddha
StormlessWolf is offline   Reply With Quote
Old 03-02-2009, 08:05 PM   #8
Rproject
Try pulling codes anyway. It may not have given you a light, but there still might be codes in there. Also, how is it on start up? Does it idle high (above 1,200)? Ours ran like manure when the idle was low (around 7-800), but after a tune up it idles at 1,000-1,500 on start up which I think is high, but it runs solid. The idle will come down after a minute or tow, but comes down slowly. Also, what is the condition of the fluids?
Our tune up included O2 sensor, vac lines, plugs, cap, air filter, better oil.
Rproject is offline   Reply With Quote
Old 03-02-2009, 08:12 PM   #9
kingjeep_4
1997 FSJ Cherokee
hows volt gage? my alternater died and was not leting my jepp get above 3,000. i think it is much simpeler then you think. sounds like an ignition problem or low voltage. idk. get the alternater checked. check the vacume lines behind the valve cover. also where they go into the manafold.
1990 YJ
1997 XJ two of them
2000 XJ
kingjeep_4 is offline   Reply With Quote
Old 03-03-2009, 03:20 PM   #10
lckdrgn
lckdrgn's Avatar
Off to dealer Thurs to find the problems. Hate paying the big bucks, just not smart enough to find my self. I'll let you know.
Kelly
Old 03-03-2009, 04:42 PM   #11
laybackman
laybackman's Avatar
Kelly
Many things can cause this but if it just keeps getting worst every time you use it or the longer you drive it, then I would guess that you have a clogged cat converter.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
Life is not what it's supposed to be. It's what it is. The way you cope with it is what makes the difference.
I think we should place all of our elderly in prisons. They will get a shower a day, video surveillance in case of any problems, three hot well balanced tailor made meals a day respecting their religious beliefs and nutritional needs, access to a library, computers, TVs, gym.
Put criminals in nursing homes. They will have cold meals, lights off at 7pm, one bath a week, live in a smaller room AND will be forced to pay $4,000- $8,000 a month!
It's pretty damn sad that we treat prisoners better than the elderly.
laybackman is offline   Reply With Quote
Old 03-05-2009, 02:26 PM   #12
lckdrgn
lckdrgn's Avatar
UPDATE:
Dealer stated bad cat. Replacement part 500.00 plus install. May need speed sensor. I picked up from dealer. Order oem for Quadratec cat muf pipe clamps etc. 250.00. Just had smogged have two years to find calif cat.
Now i'll find what the speed sensor is, and replace too.
Thanks
Old 03-05-2009, 06:29 PM   #13
tallrugbyguy
keep me informed since i have the same problems. pm if possible
tallrugbyguy is offline   Reply With Quote
Old 03-05-2009, 07:32 PM   #14
chimmychanga
This was my problem before too. I threw in a new CAT and viola~~~ problem solved.
chimmychanga is offline   Reply With Quote
Old 03-05-2009, 07:36 PM   #15
YJake
YJake's Avatar
Yeah mine did that when my cat went bad.
It fell of one day and I never looked back.
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
