94 2.5 engine pulsing? - JeepForum.com
post #1 of 2 Old 08-30-2009, 11:43 PM Thread Starter
Shawn94
My engine revs up and down while driving for about 30 seconds, then runs normal. This happens about every 5 - 10 minutes at random. It also idles normal.
Any ideas?
All I need is 4 more inches.
My flat tow trail riding 98 TJ build
Shawn94 is offline
post #2 of 2 Old 08-31-2009, 07:57 AM
idaholtby
If you don't have any codes to point you in a course of action, then I would first look for vacuum leaks and then give the throttle body and IAC a good cleaning. Remove the TB and get a new mounting gasket. Clean the bore and IAC housing thoroughly with carb cleaner and see how she does.
idaholtby is offline
pulsing vibration at 70+ mph sportcoupe TJ Wrangler Technical Forum 60 12-11-2016 10:11 AM
Pulsing vibration at 60+mph BoarderX47 TJ Wrangler Technical Forum 7 11-22-2012 01:27 PM
engine pulsing cosmo_j YJ Wrangler Technical Forum 18 12-29-2009 10:21 AM
Pulsing Vibe from 50-60 mpg missionAvs TJ Wrangler Technical Forum 10 12-03-2009 11:01 PM
Steering pulsing rick_chicago YJ Wrangler Technical Forum 2 05-07-2002 07:14 AM
