93 yj tranny/clutch problem - JeepForum.com
post #1 of 6 Old 07-28-2010, 06:02 PM Thread Starter
Joetomchick01
i have a 1993 yj, the tranny only grinds while downshifting, and my slave was leaking, so we replaced it today, well that didnt fix the problem.. clutch is fairly new, with probably 1000 miles. i dont know where else to go with it. if anyone has any suggestions, im appreciate it. thanks.
Joetomchick01 is offline
post #2 of 6 Old 07-28-2010, 07:40 PM
moonshinefuel
Well, its not a Porsche. I really don't downshift mine in the conventional sense. So I would suggest not doing that.
moonshinefuel is offline
post #3 of 6 Old 07-28-2010, 08:43 PM Thread Starter
Joetomchick01
not doing what? downshifting its pretty hard not to when everywhere i go is hilly and need to downshift fairly often and it grinds and doesnt want to go into gear.
post #4 of 6 Old 07-28-2010, 09:25 PM
NineohsevenYJ
Have you checked your clutch master cyl? I was having grinding issues, then it stopped going into gear altogether, changed out the master & it shifts better than ever now. Make sure master is full & check for leaks inside the firewall where the clutch arm pushes & on the firewall in your engine bay. I've been told that once the clutch master goes the slave is next to go, or vice versa. (and I see you chNged out the slave so master could have failed)
NineohsevenYJ is offline
post #5 of 6 Old 07-29-2010, 03:12 AM Thread Starter
Joetomchick01
yeah, i have, it looks a little wet, however my fluid doesnt look any lower. i think ill just try replacing it anyways just to be safe since i replaced the slave cylinder.
post #6 of 6 Old 07-29-2010, 06:19 AM
Roadyy
most here will advise you to change them out at the sametime anyways. Alot of the time when the M/C goes it will leak past the piston ram without leaking fluid out. I would agree to replace the M/C but only with an OEM replacement not a reman'd one from parts house.. Most ppl have them last a few months at best.
You get what you pay for,,
Roadyy is offline
Clutch/Tranny Problem???? 97casteeltj TJ Wrangler Technical Forum 8 01-09-2009 11:22 AM
tranny/clutch problem? blacksvt YJ Wrangler Technical Forum 1 08-30-2007 11:23 AM
Tranny/clutch Problem YJ-Freak YJ Wrangler Technical Forum 2 06-05-2005 03:07 PM
tranny/clutch problem? 2k3r1 TJ Wrangler Technical Forum 7 04-20-2005 10:37 AM
Tranny Clutch Problem???? bruced TJ Wrangler Technical Forum 6 12-15-2004 01:40 PM
