93 YJ replacing tcase rear output seal - no oil slinger? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 93 YJ replacing tcase rear output seal - no oil slinger?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueBest deals on Yukon Gears at JeepHut.comNeed Ace Engineering products? JeepHut has you covered.
Unread 01-22-2014, 04:48 PM   #1
mooncruiser
mooncruiser's Avatar
I have a 93 YJ and will be replacing the rear output seal on the NP231 tcase. I still have the stock slip yoke setup. I noticed there is not an oil slinger, and none of the parts houses are showing a rear oil slinger on this transfercase...is this correct?
I just figured the dummy PO just didn't put it back on after a seal replacement.
Thanks for any help clearing this up for me.
Living in God's country in southern Arizona.
84 CJ7, Chevy 350, Muncie SM465 4 spd, Dana 300, Autometer gauges, YJ spring conversion with OME springs, Bilsteins rear, Rancho 9000's...Dana 60's in the future
93 YJ - 2.5 5spd, NP231 tcase, 4.10 f & r , Posi-Lock front axle, 1" body lift, pretty stock otherwise
mooncruiser is offline   Reply With Quote
Unread 01-22-2014, 05:03 PM   #2
kloppk
Nope - no slinger on the stock setup.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline   Reply With Quote
Unread 01-22-2014, 05:30 PM   #3
jaycal3
negative
'93 Jeep YJ - 6 cyl 4.0 - 3.5" BDS - 1" Prothane BL - 33" tires - glow gauges - SpiderTrax 1.25" spacers - Rampage Recovery bumper(DO NOT BUY-RUSTED and peeling in a few yrs time)
KCCO no matter what life throws your way!
jaycal3 is offline   Reply With Quote
Unread 01-22-2014, 07:08 PM   #4
mooncruiser
Thx guys!
