93 YJ Power Steering Pump - JeepForum.com
post #1 of 4 Old 08-09-2011, 11:51 AM Thread Starter
jeepross
Hi,
Anyone ever have to replace the power steering pump due to the bearing failing, how hard to change?
jeepross is offline
post #2 of 4 Old 08-17-2011, 12:08 PM
mark0530
I replaced my whole gearbox. Took a couple hours since I didn't know what I was doing. Went slow. Also bent return line so i had to run to parts store. While there borrowed pitman arm puller. Neighbor helped me with pitman nut. Needed impact gun. over all not a bad job. I would do it again.
mark0530 is offline
post #3 of 4 Old 08-17-2011, 12:10 PM
mark0530
Sorry just realized you said pump. I was thinking gearbox. I would think pump is easier.
mark0530 is offline
post #4 of 4 Old 08-17-2011, 12:34 PM
MUDLYFE
Jeep Driver 87 YJ
MUDLYFE's Avatar
1987 YJ Wrangler
Not hard to change at all, be sure you get the new one with a reservoir and you will have to take off the pulley off the old one.
Remember. . . .A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including my life.'
That is honor, and there are way too many people in this country who no longer understand it.
-- Author Unknown
MUDLYFE is offline
Remote Power Steering pump to XJ pump write up. bigredcherokee YJ Wrangler Technical Forum 0 08-16-2010 08:37 PM
Power Steering pump leaking pink liquid - can the pump be fixed, or replaced? Sparty TJ Wrangler Technical Forum 10 01-13-2010 10:29 PM
Leaky Power Steering Pump and Steering Clunk. KATSTJ TJ Wrangler Technical Forum 6 01-03-2009 05:03 PM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 03:23 PM
Chevy Power Steering Pump / Jeep Steering Box ? glenno YJ Wrangler Technical Forum 8 01-16-2008 01:40 PM
