93 yj new clutch kit master been 3 weeks - JeepForum.com
post #1 of 5 Old 03-06-2014, 11:46 AM Thread Starter
cff36
Been 3 weeks since the install and have bled it once a week getting air every time it's the second new master. This last time I left the cap off while I did it and filled it before I let off the clutch. It's rock hard now do you think the 2nd new master is shot or could air be a problem for this long
cff36 is offline
post #2 of 5 Old 03-06-2014, 11:47 AM Thread Starter
cff36
Yes the kit came with new slave and no fluid leakage
cff36 is offline
post #3 of 5 Old 03-07-2014, 02:32 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Did you fully "bench-bleed" the master cyl prior to install? I have done this in the past, (or thought I did it really well....) and still had a soft pedal. I have had to disconnect and inject brake fluid retrograde thru the connections, as well as aspirate air out with a needle. Some are more difficult than others to get the air out, it can be messy and brake fluid will eat paint off your rig, so use a lotta towels/plastic if you have a tendency to be messy.
EDIT--my apologies, I was describing more the feel of a soft BRAKE pedal, however the bench bleeding of the master cyl still applies, clutch master or brake master.
Glad you seem to be back on the road, at least for now.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 5 Old 03-08-2014, 04:23 PM Thread Starter
cff36
Thanks for the info I bled it 3 more times and is on its third day and still holding so hopefully the air is all out
cff36 is offline
post #5 of 5 Old 10-01-2014, 06:09 PM Thread Starter
cff36
Took mine almost a month to get all the air out it'll happen good luck
cff36 is offline
