93 yj hard doors - JeepForum.com
post #1 of 8 Old 07-31-2002, 08:04 AM Thread Starter
leon94Z71
93 yj hard doors
hey, any easy way to remove hard doors on 93 yj? I'm looking to get the mirrors to mount on windshield, but can't figure out easy way of removing doors (other than the 6 hex screws in hindge for each door). any advice appreciated.
Leon
leon94Z71 is offline
post #2 of 8 Old 07-31-2002, 08:43 AM
YJXJBill
Your doors are made to remove easily. Look at the bottom of the top hinge on each door. There should be a nut that holds the door on. Remove the nut and lift straight up on the door. Make sure you undo the check strap on the inside of the door (lift it up off of the hook.
Hey, presto! no doors!
Bill
'94 YJ
'95 XJ
YJXJBill is offline
post #3 of 8 Old 07-31-2002, 09:13 AM
Kev
Master of the Obvious
Kev's Avatar
If the doors have never been off before, it is likely that they will be hard to pull off the first time. Just soak the hinges with WD-40 or something and let it set for awhile (I would wipe off the excess so you don't damage the paint). Then lift up like YJXJBill posted, but becareful because when they break loose you can about throw the door if you're trying too hard . I also recommend rolling down the window first.
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #4 of 8 Old 07-31-2002, 11:15 AM
RCHavok797
RCHavok797's Avatar
Definately use some penetrating oil on the hinges before tyring to remove the doors. While you are pulling up on the door try swinging it back and forth which should help you to get it out easier without killing yourself or the door.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #5 of 8 Old 07-31-2002, 11:58 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I'm sorry .. I am not sure if I am reading the question correctly, but I understand it that you are wishing to remove the stock door mirrors off the doors and put CJ style mirrors onto the windshield hinge.
If that is the correct way to read the question .. then you would have to use the Torx bits to remove the bolts. You might wish to replace the hinges at the same time (they seize up on occasion) and replace the bolts with new ones. A good set of stainless steel hinges are a great addition to your unit .. and matching stainless CJ mirror brackets would be a must in that case
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #6 of 8 Old 07-31-2002, 12:54 PM
skr91yj
Are you trying to tell me that they have doors for Jeeps? I almost forgot mine are somewhere buried in the back of my garage.
skr91yj is offline
post #7 of 8 Old 07-31-2002, 01:04 PM
Kev
Kev's Avatar
That sounds cold in a Chicago winter...brrrrrrrrrrrrrrr! I really hate my doors too, until January, then they come in handy for keeping the cold and crap out!
As far as mount mirrors and removing doors, I reread the post and think he is asking about both. If you have the half-door style mirrors I recommend get some mirror movers, but if you have the cheesy small ones like I do, you'll have to go with the CJ style or something
Kev is offline
post #8 of 8 Old 07-31-2002, 01:35 PM
skr91yj
Warrior makes a relocation bracket that will not only move your mirror mounts to the window hinges, it also gives you a mount for a pair of offroad spotlights. as far as going doorless in Chicago, you dress warm, beef up the heater and don't drive on the highway.
skr91yj is offline
hard topw fulls doors vs soft top w half doors airdevil85 YJ Wrangler Technical Forum 5 01-13-2010 11:37 AM
Hard Top - Hard Doors Improvised Rattle solving thread bparsel YJ Wrangler Technical Forum 7 07-22-2009 08:23 PM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 03:57 PM
Soft top? full hard doors vs. half doors jgarden TJ Wrangler Technical Forum 8 10-17-2004 03:00 PM
Buying TJ with hardtop & hard doors, but I want a soft top & half doors xxxxxxxxxxxxxxxxxxxgksspot TJ Wrangler Technical Forum 11 10-26-2003 10:16 AM
