'93 YJ front wheel bearings - JeepForum.com
post #1 of 3 Old 12-18-2001, 09:10 PM Thread Starter
Colby Bruce
Has anyone ever replaced these or do they have to be done at the dealer? I think mine are making some noise, and the manual says the dealer must do this work. TIA
Colby Bruce is offline
post #2 of 3 Old 12-18-2001, 09:38 PM
osburn
osburn's Avatar
The bearings themselves are non-serviceable. You have to replace the hub/spindle/bearing assembly as a unit. It's not a real difficult job. But it does require specific tools. Someone on this board just recently went thru this and hopefully will pipe up. I'd recommend you do this yourself. It's good experience and it means you'll have the tools to fix an axle on the trail. There's no rocket science to this. Just look at it and you'll be able to tell what bolts need to be pulled. Once all the bolts are out, beat on it a few times with a hammer if it's stuck to break the assembly loose from the knuckle. Keep the old one for a trail spare.
Matt Osburn
Score 1032
osburn is offline
post #3 of 3 Old 12-19-2001, 12:04 PM
gifargis
Chiltons Book for YJ's is the best source from information on this..
I followed the instructions and the parts were not to expensive.. and it only took about 3 -4 hours for both sides..
See y'll on the trail.
gifargis is offline
How to remove front wheel bearings/hub from front axle? Tshark299 YJ Wrangler Technical Forum 10 09-17-2010 07:55 PM
front wheel bearings 88wagon TJ Wrangler Technical Forum 2 12-21-2007 08:49 PM
Front Wheel Bearings snwchris TJ Wrangler Technical Forum 2 03-13-2007 11:04 AM
Front wheel bearings.... KC2OTE YJ Wrangler Technical Forum 7 01-01-2006 02:10 PM
front wheel bearings D30 yjinprogress YJ Wrangler Technical Forum 2 08-25-2004 10:12 AM
