93 YJ clutch question - JeepForum.com
post #1 of 6 Old 07-04-2001, 12:05 AM Thread Starter
svtjones
I have a 93 YJ. I have heard different things about the 93 having a hydralic clutch master and slave cylinder. I know of the existance of the Master cylinder. I have heard that there is a slave cylinder and it is encased in the transfer case. I cannot find any information that supports this though. If anyone knows of a link or personal information, please advise.
Thank you.
svtjones is offline
post #2 of 6 Old 07-04-2001, 12:37 AM
osburn
osburn's Avatar
On your particular Jeep, you basically have an internal slave cylinder. And it is located inside your bellhousing. This makes your replacement parts sorta expensive and the work a pain since you have to drop the tranny anytime you need to replace it. One more year later and you would have had an external slave cylinder. Cheaper and much easier to replace.
Matt Osburn
Score 1032
osburn is offline
post #3 of 6 Old 07-11-2001, 01:24 PM
Nightclaw
I'm having the clutch replaced on my YJ today. At a dealer no less, so you know I'm getting hosed on the price...
Anyhow, osburn is correct about the slave cylinder location. Royal PITA, which is why I'm letting someone else skin their knuckles... One item of correction however, it seems the '94s were a "transition year." Mine was built with the slave inside the bell housing, but with the ABS rear axle (part number fun - woo hoo! ). Just thought I'd share. Cheers!
Nightclaw is offline
post #4 of 6 Old 07-12-2001, 01:20 AM
renegade0351
just replaced the clutch, presure plate and slave cyl. in my tranny, piece of cake. i made a transmission mount [like jc whitney sales] for my jack and it worked like a charm, out and back in in 3 days working on it after work, ok me and my brother. only cost was for the parts.
89 sahara, 4.2 , k551 weber, nutter bypass, tuffy stereo security console & under seat security drawer, 4'pro comp & 3'body, front waggy44 w/detroit & 4.88, rear waggy44 w/detroit & 4.88, teralow sye, tw's cv drive shaft {rear}, warn locking hubs, boomerrangs all around, 35x15.50 tsl-sx swampers { love that roar}.
renegade0351 is offline
post #5 of 6 Old 07-12-2001, 12:15 PM
rayray
rayray's Avatar
Can the bell housing off of a newer YJ be swapped in to move the slave to the outside? Then just replace the fork and arm assemply. Seems like it would be a nice upgrade.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #6 of 6 Old 07-12-2001, 02:30 PM
Nightclaw
I know for a fact it can be done, as I have seen a couple rigs with this mod. I don't know if it was a kit or a custom fab though.
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
clutch question.... camper49 TJ Wrangler Technical Forum 2 09-25-2007 08:11 PM
clutch question bughunter YJ Wrangler Technical Forum 0 10-06-2006 07:46 PM
New clutch question YJfrom94 YJ Wrangler Technical Forum 3 06-29-2005 10:55 AM
clutch question Gper4life YJ Wrangler Technical Forum 6 01-02-2004 06:55 PM
