93 YJ Anti-Lock Brake ABS Removal - JeepForum.com
post #1 of 12 Old 11-11-2009, 08:02 PM Thread Starter
leviathan
Greetings,
I recently picked up a 1993 YJ Wrangler from a friend of mine. It runs good enough but all the brake lines are rusted and the flex hoses are dry rotted. So I'll be replacing most, if not all of the brake system.
That being said, I've thought about removing the ABS system. I figure it's one less point of failure and have never been a fan of ABS. Any thoughts on the subject would be great, I'd like to get this bugger running for the winter...so I can use my garage ;-).
Thought about the disc conversion as well but seems that would require quite a bit more work and cash and perhaps could just as easily be done at a later date.
Thanks in advance.
leviathan is offline
post #2 of 12 Old 11-11-2009, 08:06 PM
Super D
Somebody else can correct me if i'm wrong. But i'm pretty darn sure' 93 YJ's did not come with ABS brakes.
Super D is offline
post #3 of 12 Old 11-11-2009, 08:10 PM
grnjp88
1994 XJ Cherokee
I believe it was offered as optional equipment.
1994 Jeep Cherokee Sport
4.0L, 5spd M/T, 2DR
grnjp88 is offline
post #4 of 12 Old 11-11-2009, 08:13 PM Thread Starter
leviathan
Indeed, it was optional, his parents probably made him get it for that extra bit of safety.
post #5 of 12 Old 11-11-2009, 08:14 PM
chicalibro3
they definitely have power brakes, but i'm not sure they all came with ABS. Do you know if you definitely have ABS?
chicalibro3 is offline
post #6 of 12 Old 11-11-2009, 09:18 PM
TSEJEEPERS
Mine does not have ABS either.
Not claiming to know alot about ABS but I would think if you swapped the master cylinder from a non ABS Jeep you would eliminate it. Maybe someone else could chime in on this.
Not sure if you would have to do something with the computer though.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #7 of 12 Old 11-13-2009, 09:22 PM
Raloma
Mine definately had ABS
Raloma is offline
post #8 of 12 Old 11-13-2009, 09:33 PM
Louie4
Mine is a '93 Sahara and it has ABS. I even had to get some spare D35 shafts out of a GC with ABS because they are 1/2" longer. If you don't want to fool with the ABS you can simply unplug the module under the seat or from the pump (I think) and if you want remove all the ABS lines going to the wheels. If you do this you will want take the center cluster out and pull the ABS bulb because it will stay light all the time. I had mine unplugged for a little bit, but hooked it up just because.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 12 Old 11-17-2009, 10:35 PM Thread Starter
leviathan
Thanks for all the responses. Yes, I'm sure it has ABS. And if possible what I'm looking for is;
What parts need to be changed to remove the ABS altogether?
post #10 of 12 Old 03-05-2013, 10:39 PM
jediapprentice
bringing this thread back from the dead, i have a 93 with ABS and i am interested in what is involved to remove ABS system.
jediapprentice is offline
post #11 of 12 Old 01-07-2015, 03:24 PM
Shoaib
can anyone let me know what anti lock and maint req'd lights for in yj' cluster. thanks
Shoaib is offline
post #12 of 12 Old 01-07-2015, 04:08 PM
Mark05059
Shoaib welcome to the forum. Please post up a new thread so you can follow it instead of posting in a thread that was started 5 years ago... Must be a zombie since it died once
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
Anti lock brake help HCU removal yj_hank YJ Wrangler Technical Forum 3 07-17-2010 07:59 PM
Anti lock brakes TJ Clay TJ Wrangler Technical Forum 4 01-17-2008 01:58 PM
anti-lock w/8.8 bamato YJ Wrangler Technical Forum 3 05-22-2007 06:39 PM
Anti-lock brakes? PearlJam1003 TJ Wrangler Technical Forum 22 01-16-2007 09:22 PM
do i have anti-lock brakes ForkLift TJ Wrangler Technical Forum 9 01-29-2004 10:42 PM
