93 YJ 4.0 what tranny? - JeepForum.com
post #1 of 4 Old 05-08-2002, 05:52 PM Thread Starter
West
I'm looking at a 93 YJ 4.0 with a 5 speed for parts. What tranny should that have? AX-15? If it is, can that be hooked to a dana 300?
West is offline
post #2 of 4 Old 05-08-2002, 10:27 PM
Tailgummer
The '93 5 speed will be an AX15 and yes you can bolt the D300 to it BUT you will need to do some machinework to the seal flange in the D300 input shaft. Also the output is on the wrong side for a YJ (ie the D300 output is on the passenger side). I assume you want to put all this into a YJ.
Good Luck
Chuck
'91 YJ, 4.0L 5sp, Atlas II, RE SOA + 2"BDS, 35" Explorer Xterrains, ARB's & 4.56 gears, WARN 9000i
WWW.4x4xnorthwest.com
Tailgummer is offline
post #3 of 4 Old 05-09-2002, 04:05 AM Thread Starter
West
I bought the motor to swap into my 84 CJ7. I have a T5 in it now. Any opinions on whether it's worth it to make the AX-15 fit?
West is offline
post #4 of 4 Old 05-10-2002, 07:02 PM Thread Starter
West
opinions anyone?
West is offline
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 06:11 AM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 06:10 AM
Should I repair Tranny seal or replace Tranny? Yankee-Juliet YJ Wrangler Technical Forum 10 03-29-2009 04:41 PM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 08:16 AM
How much heavier is an auto tranny than the manual tranny? CB3 TJ Wrangler Technical Forum 9 12-24-2007 06:35 AM
