93 YJ on 36" swampers - JeepForum.com
post #1 of 19 Old 06-24-2010, 08:27 PM Thread Starter
gtome
I tried posting this in the buying section, but getting no advice there.... so I thought I would ask here. I am going to look at this Saturday am, so I couldnt be much more patient. My original post read as this:
Just looking for some advice. I have read about how risky it is to run anything larger than 33's on stock axles. I have found a pretty nice 93 auto that is riding on 36" swampers. He bought it that way and thinks the axles are stock (but doesnt really know). He also never took it off roading, but did use it to go shark fishing on the beach. Also no idea if it has been re-gear'd and doesnt know how it is lifted. He has paid to keep it maintained and looks pretty rust free from the pics.
Just wondering what everyone here thinks. Could the big tires weaken the axles (if they are stock)? I am going to study and memorize the different rears to help me identify them when I go. But obviously cant check the gears to see if they are stock. Anything else I should look for when inspecting this thing? Here are the pics I have:
gtome is offline
post #2 of 19 Old 06-24-2010, 09:08 PM
wrangler76
It looks like a nice YJ.... I don't think I'd be happy to run 36's with stock gears and it looks like you might have some significant clearance issues. It might be a good purchase then swap the 36's for 33's.... It's always hard to give really good advice on these jeep purchase questions without seeing the jeep in person.
wrangler76 is offline
post #3 of 19 Old 06-25-2010, 07:26 AM Thread Starter
gtome
Yeah I know its really tough to tell from pics, and really I was just looking for what to look out for. I restore cars for a living and I can tell all the normal stuff. I was more curious of the ill affects of the large tires.
And I was thinking exactly the same thing. When the tires wear out (if they arent already) putting some 33's in place of the 36's. Maybe even bringing it back down a bit, I really like the LCOG theme. It will have at least tube fenders too at some point, so clearance really isnt an issue im too worried about.
gtome is offline
post #4 of 19 Old 06-25-2010, 03:21 PM
Mazdarx
I don't think it could be taken offroad much that way, and it doesn't look as though it has been. I would guess it to be stock axles as pavement princess types usually don't change those. It is possible to tell if its been regeared, you have to lift up the back of the Jeep and turn one wheel and count the driveshaft rotations, something like that. I'm sure somebody here knows the exact procedure. You can see there is only minimal tire clearance there, and in fact in the one picture showing the tire close up, you can see that it has been rubbing the flare.
-My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline
post #5 of 19 Old 06-25-2010, 04:12 PM Thread Starter
gtome
Yeah, I guess I have read about counting the axle rotation vs the driveshaft rotation to get the gearing. I dont know how accurate it would be, but I guess it doesnt really matter that much to me. I wouldnt have it long before I put 33's on it.
Suppose that would be a 4" lift (yeah, he doesnt know that either)?? Doesnt look to me by this larger pic to have a body lift.
gtome is offline
post #6 of 19 Old 06-25-2010, 04:16 PM
ImpactFabWorks
the axle rotation to drive shaft rotation is actaully really accurate. I don't think it's a 4" lift if it clears 36's. There is no body lift and isn't cut. get under it and look around for part numbers on the springs and google it. maybe it has a SOA?
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #7 of 19 Old 06-25-2010, 04:24 PM Thread Starter
gtome
brian_nichols: Good call!! Didnt even think to check that in these pics. SOA it is.
So knowing it is SOA with the 36's, anything else I should be on the lookout for when I go look at this in the am? He wants $4500 for it, and from what I can see, $3500 sounds more reasonable.
gtome is offline
post #8 of 19 Old 06-25-2010, 04:31 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
betcha the steering is jacked up on it and need to be done of its a pavement princess to.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is online now
post #9 of 19 Old 06-25-2010, 04:34 PM Thread Starter
gtome
Can you be more specific? Steering box? Tie rods? ALL of it??!! I was thinkin about driveline angles and such.... didnt think much about the steering
gtome is offline
post #10 of 19 Old 06-25-2010, 04:35 PM
SteveJcoYJ
get a picture lower to the ground of the rear, then we can verify lift and what rear it has an go from there.
the above procedure will be the easiest way to tell what gears you have, an it really isnt that hard
if it accelerates like a freight train then it might just have stock gears ( 3:73's or 3:37's im sure someone can verify for your jeep or you can look up the stock specs in the f&q an find out yourself), and regardless of what examples you find of what the stock diffs can and can't handle tire size wise just remember, they were designed to only have to handle a 28" tire. if its a dana 35 in the rear, it may be fine but you are without a doubt seriously pushing it.
considering it looks like it has a soa with stock leafs at my best guess from your pics, im sure one the PO's had the jeepbility to throw a dana44, chevy 10 bolt, or sterling rear in it. but your gonna have to get pics for us to be able to tell.
if its has 4:10's in any kind of beefier housing then it should be good to go
SteveJcoYJ is offline
post #11 of 19 Old 06-25-2010, 04:35 PM
ImpactFabWorks
I would like to see how the steering is set-up. a lot of people do SOA and just neglect the steering
post #12 of 19 Old 06-25-2010, 04:37 PM
SteveJcoYJ
see if the tie rod ends were flipped to the top of the knuckle, see that it has a real dropped pitman arm (not one of those cut in half and weld back together longer jobs) and look at the angle of the rear drive shaft, does it have a transfercase drop or a slip yoke eleminator installed on it
it costs money and takes knowledge to do a good soa job
post #13 of 19 Old 06-25-2010, 04:40 PM Thread Starter
gtome
Ok, I will get some pics with my cell in the am. My Droid takes pretty good ones. Then Post them up here for all to see. SO I want pics of the whole front steering (tie rods, pitman, etc..) and suspention, the rear drive shaft and angle, and a pic of each diff for verifiaction. Anything else?
gtome is offline
post #14 of 19 Old 06-27-2010, 02:59 PM Thread Starter
gtome
Boo! Turns out the guy had to work and I could go look at it. Will have to try again later in the week
gtome is offline
post #15 of 19 Old 06-27-2010, 03:01 PM
ImpactFabWorks
HAHAAHA stupid people with jobs screwing up this country
Will a 3" body lift allow me to run 44" super swampers? Morpheus Wrangler General Discussion 9 01-03-2010 06:45 PM
34" Swampers with the 2.5? Kman1983 YJ Wrangler Technical Forum 2 06-23-2009 11:53 AM
New swampers ONEMORE2 YJ Wrangler Technical Forum 4 11-08-2007 10:43 PM
pics of 33x14.5" swampers on yj cvweaver95yj YJ Wrangler Technical Forum 1 07-11-2003 05:06 PM
6" skyjacker w/ 36x12.5 swampers TwinTurboTA TJ Wrangler Technical Forum 1 04-03-2002 04:27 AM
